#31
This is getting almost as good as a Hytran debate. My truck is better than yours.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#32
#33
My 2 cents is a 1st gen dodge cummins w250 pickup. Strong and dependable
#34
Picked this up last spring after chasing it on E-bay till the rebates kicked in and I'm lovin' it. 3500 Cummins powered Laramie Longhorn. Gets 14+ mpg hauling a 1181 Lance truck camper around.
Owned Chrysler products for 55 years now, period. It' MoPar or NoCar! |
#35
You definitely got the right idea of buying a vehicle. Good luck in whatever you choose.
-Rick IH 782 IH 126 CCC 1863 |
#36
I've have an '03 Silverado 2wd, ext cab with the 4.8 8cyl. Very few issues in the 230000+ miles. Early on the cat conv went bad and was replaced at about 40k, the replacement is still in there. One of the computers went bad at about 50k and was covered by warranty, it was one of the non-recall / recalls they do if it is for other work but mine happened to go bad on the side of 495.
Other than regular maintenance I had a fuel pump and water pump replaced at about 180k and the brake lines rusted out and had to be replaced. I hope to get another 3 years out of it, but I would buy another GM as I really like the 4.8, enough power for my occasional towing of tractors and gets about 19mpg. Only one rust issue is on the passenger rear wheel well about the size of three quarters side to side. The transmission is a little rough going from 1st to 2nd early on cold mornings but i take it easy until it warms up. I am very careful about the weight I tow now since i don't want a big bill surprising me. Really got a workout towing a loader I found recently but the tranny seems to have survived the strain. |
#37
Chevy all the way or GMC. Way more comfortable riding vehicle, and like everyone else says the 5.3 is a great engine.
I'd recommend a Chevy Avalanche too - I've driven an '05 for 5 years now and I think my next vehicle will be a newer Avalanche. It's currently hooked to my trailer with a Cub Cadet 149 on on the trailer. I've hauled everything from my Son's '04 Duramax(wow was that heavy), to an empty trailer to my 36' travel trailer with my Avalanche. Its never let me down. It's going to need tires soon, do I install new tires or is it time to buy another Avalanche? Probably should go with tires... It has 200xxx miles and it sill going strong. |
#38
Another vote for the Chevy/GMC camp. I love love love my 2001 1500 Silverado with the 5.3. Plenty of oomph for whatever I've needed it to do and she has just been reliable. No complaints here.
-Ryan
#39
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
#40
The truck I just recently got rid off simple to downsize and get a but more milage was a 1998 gmc k1500. Was what was called a "heavy half" while it was a half ton trucked it's frame was boxed almost all the way as well as had the heavier 14 bolt non floater rear axle (standard 14 bolt was full float) . Had a 4 bolt main roller cam vortec 350 with a 4l80e transmission floor shift tcase. G80 locker in the rear. Weighed in at just over 6000 lbs it was extended cab short bed. Loved every bit of that truck and usualy got around 18mpg highway unloaded.... had a little over 451k on it when I sold it to my buddy a little over a year ago and I'm sure he's approaching 500 by now he drives it daily. Options is what really makes a vehicle and good maintenence. I can be 95% sure any of the half ton vehicles sold now will perform just as good as any of us need them to. Figure out what your wanting it to do and go from there. Look at the problems of the trucks your interested in have. Every manufactures have its pros and cons. Just have to see which ones outweigh the next...
