Old 05-24-2016, 08:08 AM
sawdustdad's Avatar
I've had good luck with solid carbide twist drill bits. They are brittle, so easy to break, but they will go through the set screw like "butta."
drillsandcutters.com sells them. buy a couple of each useful size. You will break them from time to time. Used one to drill out a spirol pin at the bottom of the manual lift arm of my 148 project.
Old 05-24-2016, 11:03 AM
Originally Posted by ironman View Post
For extraction, I was wondering if anyone has tried using these things. Kinda similar to an easy out, but you can go both ways, loosen and tighten. Looks doubtful though that the 1/4 inch one could go down the hole far enough to reach the lower allen screw.
http://www.lislecorp.com/divisions/p...s/?product=376
You can use a #15 torx bit, they are a little snug and will need to be tapped in with a hammer. I've used them before with mixed results, they work better if the side of the set screw isn't cracked.
