Old 07-18-2016, 06:47 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Originally Posted by DieselDoctor View Post
There was some discussion earlier in this thread about the substitute upper radiator hose, Kubota part# K7311-85150, that needs to be modified. I took my hose back off and snapped a couple of pics so everyone can understand what needs to be done.
Thanks for the pictures and further explanation. This makes it perfectly clear. On the implement shaft use Kroil like suggested or PBlaster to free it up. On my 782D, I drilled a small hole in the center of the "outer shaft" then used a needle-type grease fitting until I had grease coming out both sides to try and keep it freed up,
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-19-2016, 12:43 AM
DieselDoctor's Avatar
Thanks for the suggestions on dealing with the implement shaft. I am a believer in the magic powers of both Kroil and PB Blaster, but I am not always a patient man. When it comes to cautiously heating, tapping, apply oil and repeating the process until the part is free again, I usually get carried away with the tapping part. So knowing my limits, I took the whole frame to work and used the hydraulic press and some very good blocking to support everything while I applied some pressure on the shaft. A little heat and 11 TONS of pressure and it finally came free. After cleaning all the pieces, they slip fit within each other again. Given that there already were two holes in the bushing section of the J arm, I tapped one to 1/8" NPT and installed a grease fitting. It won't seize again!
Onward to sanding the frame and some high build primer! I need to see RED!
Old 07-19-2016, 12:51 AM
You can't use that spring pin you installed. A spring pin is not the same as a spirol pin. The spirol pins will handle more load. You will just break the spring pin in short order.
Old 07-19-2016, 01:20 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Whizz on it, just weld the pup
1- 1200 in pieces
1- 1864 in pieces
Old 07-19-2016, 01:34 AM
aagitch's Avatar
aagitch aagitch is offline
He could if he doesn't plan on removing it again.
Adrian
2072 (789513)
Old 07-19-2016, 09:33 AM
Thanks- I'll change them out to spirol-loc pins. These were the pins that were in it when I tore it down.
Old 07-24-2016, 11:50 PM
Made some more progress. Frame has been sanded to remove all rust, scale and most of the old paint. Today it got two coats of high build epoxy primer, I'm pleased with the results as even the pitted sections are smooth. After some cure time, I'll wet sand it to break the surface and shoot it IH Red. The frame was in great shape, no cracks and all threaded holes had good threads. The only problem so far has been the implement shaft arm and that's been addressed. These little guys are tough. No significant issues after 32 years!
Old 07-25-2016, 04:37 AM
Dirty Steve's Avatar
Hats off! You are doing it right. Keep up.the good work!
Old 07-25-2016, 10:00 AM
Mooner's Avatar
Mooner Mooner is offline
Wow! Impressive work! The 782D may be my favorite Cub of all. So hard to choose. Lol
Thanks for sharing...looking forward to seeing the progress.
Old 07-25-2016, 11:15 AM
Looking good! Thanks for the pic and update.
