#31
I'm not going to disagree with anything you said. ![]() I just want to say that while it isn't worth buying $600 worth of material to paint one Cub, a gallon should do at least two. If you store the supplies like they should, the shelf life should be at least a couple years, if not longer. I know I've grabbed paint I had on the shelf that was older than that and it was still fine. So, if $600 can do two, that's $300 per machine. Now, Nason (my personal brand of choice) isn't quite that expensive, or at least last gallon I bought was more like $200 maybe $250 a gallon (depending on color and type). By the time you get supplies, you'll have about $300 maybe just a bit more.... but again, that should do two machines. So, now your at $150-$175 per machine. Back to Ironguard. At $60/gal, plus material, your at at least $100-$125 per machine..... so, is it worth it to spend $50-$75 more at the far end to use better paint? In my mind, yes. Is it as easy to shoot...... no. But it is just so much better. That's where I'm coming from.
#32
If you can paint two cubs with one gallon of paint then you must be some kind of wizard, yellow covers horribly regardless of brand and I usually put on 5 coats to get good coverage even with the expensive paint. I see alot of cubs at shows where you can see through the paint to the primer but the average person probably can't see it, those must be the guys that can paint there cub with two quarts.
#33
I am sure glad you guys mentioned how much paint you use when painting a Cub. If it takes you a gallon no telling how many gallons it is going to take a rookie like me to paint my Cub.
#35
I did shoot Caterpillar yellow with Nason. I just thought of that. But I don't recall how much I went through. It was just for an engine out of a dozer, but for a rebuild at over $20,000, I wanted it to look like it was worth the price.
#36
Dozers and Cub Cadets. J-Mech you have toys in all sizes.
#37
#38
No, no. I used to own and run a shop. We specialized in heavy equipment, but also worked on cars, trucks.... ok, so we would work on anything that paid, but my "specialty" was heavy equipment. The Cat motor was a paying job.
![]() But I do have a lot of toys.... but sold the "bigger" ones ..... for now.
#40
What the heck are you guys spraying? I spray PPG Shop-Line paint that cost somewhere between $40 & $50 a quart + the reducer & hardener which isn't that much more. I never could understand that they don't discount the paint if you buy more. I can buy (4) quart cans or (1) gallon can for the same price. A quart of epoxy primer and pint of hardener runs $48.00 out the door and I think the 2k primer is a little cheaper. I agree, yellow paint doesn't cover well. I think it takes me a quart to spray a deck but I spray outside with a pos Ingersoll Rand HVLP gun.
I'm not knocking the Iron-guard paint, I just don't have a dealer near me and I would have to have it shipped to me which sounds like a PITA. Tim & J, I highly respect both of what you guys add to this site and I'm not disagreeing with either of you but I just wanted to throw out there my (limited)experience I have had spraying paint.
