Old 11-21-2016, 10:45 AM
Wayne Wayne is offline
I have spark with the old coil. Not sure how wise it is to run it with a leaky coil though. I might not have any choice on Wednesday when it snows again, because I won't be able to get a new coil by then.
Cub Cadet 2166
Old 11-21-2016, 11:00 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Amazon Prime (have it tomorrow if you're willing to pay next day shipping)
https://www.amazon.com/Stens-460-048...+coil+k+series
(I know that may not be the exact one you need, but they should have it)
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 11-21-2016, 12:55 PM
The oil is for cooling. Worst case it burns up the widings. I doubt it's leaked out enough to be an issue seeing as how they are mounted upright.
Old 11-21-2016, 01:10 PM
That's the one I bought recently that just died. I'll probably give a replacement a try under warranty, since I have my old one as a backup for emergencies.
Any suggestions for "real" ones if the replacement fails too? I confirmed these are Chinese.
Cub Cadet 2166
Old 11-21-2016, 02:11 PM
Lots of guys run the Bosch Blue coils with no issues. You can get them at most part stores, or several online vendors.
I use Napa coils, Prime Line or even Borg Warner with no issues. Just make sure you get the correct coil. You need an internal resisted with about a 3.5 OHM rating if memory serves.
Old 11-21-2016, 04:16 PM
mortten mortten is offline
NAPA coil number is IC64 if interested.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-07-2016, 07:16 PM
s022mag s022mag is offline
I've got a 1810 not sure of the year and I also have no spark, I see that I need to check the coil but can't seem to find it. There seems to be a lot of flashing covering the motor and hiding where the coil wires go. I doubt its ever been replace. Where is the coil located?
Old 12-07-2016, 07:34 PM
OK, first of all your tractor is a CCC/MTD so you should start a thread in that section. Second your tractor has a magneto, not a coil. It is located under the blower housing. You will pretty much need to remove the engine to get at it. You should have a white wire someplace on the engine harness that grounds the mag to shut the engine off, if you disconnect it and crank the engine and it starts then the problem is someplace else. If it won't fire then get ready to pull the engine and have a look under the tin work.
Here are 2 manuals you should download.
Mag 18 http://www.onlycubcadets.net/forum/s...ead.php?t=4648
Chassis service http://www.onlycubcadets.net/forum/s...ad.php?t=13226
Old 12-07-2016, 08:02 PM
Thanks man, not sure what CCC/MTD is but I see the white wire as it runs down with the spark plug wires. I'll disconnect it from the accessible side and see what happens. If no start then I'll just continue my search for a 4WD and plow to get me through the winter.
Old 12-07-2016, 08:13 PM
john hall's Avatar
You tagged on to a thread that exists in the IH built section. Yours was built after Cadet was spun off to MTD and Cub Cadet Corporation was formed. You'll most likely get more views and responses by starting a thread in the proper section.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
