Old 12-09-2016, 10:46 PM
Originally Posted by taylorjm View Post
I also removed the front wheels because the bearings were loose. It's much easier to check the alignment using just the bare axles without the tires, especially when your bearings are worn and the tires wobble!
Funny.... I think it's MUCH easier to align anything with the tires on. So do alignment shops. They don't take them off either. How in the world do you check tow-in with no tires on??
Originally Posted by Nightow1 View Post
BUT it works great
Think i will just leave mine till I tear her down next winter.
Why not just unbolt them and turn them over. It won't change any of the adjustments..... It will still work fine and not hit the subframe, which it looks like it already is.
Old 12-09-2016, 10:48 PM
Nightow1 Nightow1 is offline
No she dont hot at all, surprisingly
Old 12-09-2016, 11:14 PM
Are you drinking again? It's not even morning!
Old 12-09-2016, 11:20 PM
Jibber's Avatar
Jibber Jibber is offline
Yep, doesn't hit my subframe either. Time for you to go to bed Johnny!!
Old 12-09-2016, 11:27 PM
Well boys, I'm quite certain it would if you flexed the axle enough.
It's a long time from my bedtime. According to you profile Jibber, at your age I'm surprised your still up.
Old 12-10-2016, 08:10 PM
taylorjm taylorjm is offline
I found it was easier to take a framing square against the frame and adjust the tie rods until the axles were in line with the square, so at 90 degrees to the frame. Can't do that with the tires on.
Old 12-10-2016, 08:38 PM
I always just put a mark in the center of the tire on the front and the back and use a tape measure. Must do work pretty good because I would do it to cars after front end work, then take them to the alignment shop and they might be 1-2 deg off. Pretty easy on a GT as you can do it by yourself.
By the way, they should toe in, not be square. Check your book. Should say 1/8". I'll go up to a 1/4".
Old 12-10-2016, 08:44 PM
Yup. They are.
Old 12-10-2016, 08:46 PM
Yup. They are.
How would you know if you adjusted it with the tires off?
Old 12-10-2016, 08:52 PM
Because the axles are not perpendicular to the frame. They are turned in a bit.
