Old 09-27-2017, 06:38 PM
johncub7172's Avatar
Smile
What a hoot! The Firestone ag tires came in today!!! Oh yea it happened!! Now I'm looking at the sleeve hitch from Extreme. Got a few odds and ends coming from CCSpecialties as well.
Old 09-27-2017, 07:19 PM
Keep up the good work, looking forward to some pictures.
Up to 534 and counting...
Old 09-27-2017, 11:10 PM
"Sounds" good and all...
But sure would be nice to see all your work, and new thingys...
Old 09-28-2017, 12:34 AM
Cool
Lew, Zippy1, and the Gang, thank you! I need to get moving on the project, so I thought I'd start with some upgrades, and cosmetic stuff.
So, the very next thing I do is to finish painting the disk brake assembly, get these rims painted and mount the tires. Reminds me that I need new valve stems as well
Then, I'm still going after opening up the hydro pump for a basic inspection. I have the complete rebuild kit if needed. Then go for painting the cast iron section of that pump, and reassemble. Then disassemble the rest of the chassis as far as I can, and clean it up real spiffy before the cold weather settles in.
I do have the trans axle and new 1/4" rim spacers painted up nicely, with some finishing touches! Looking forward to working on the 1450 all day, cause the wife will be at work for most of it!!! I'll get picts up of these new ag tires I got!
Old 09-28-2017, 09:36 AM
Thumbs up New rear tires came yesterday,....!
Here they are! They feel like they around 26# each, and made in
[/IMG]
[/IMG]
And of course, those came from:
www.millertire.com
1-800-621-1955, ext.4
Have a great day guys! At least it's cooled down in my neck of the woods. Should be a nicer day at work
Old 09-28-2017, 10:51 AM
twoton twoton is offline
Good lookin' tires there! Now it's time to get those hands dirty!
Old 09-30-2017, 09:53 PM
Those are the real McCoys! I don't know about other tires, but these are pretty cool and can't wait to get them on the 1450!
On another note, the rear rims are done and I pick them up on Monday
Today, I got into the thick of it. Took the 1450 out back and degreased, and washed it up. Dried with compressed air. I pretty much got a handle on what is going to get rattle can painted, I'm only planning to touch up the frame and what not. Here are a few pictures:
All cleaned up! I had used PB Blaster, hand cleaner, car wash soap, hot water, garden hose, and air to get the job done.
[/IMG]
A shot of how I made the whole clean up possible, with the '69 IH #2 cart and a 2' x 8' x 3/4" board, and the model 72:
[/IMG]
I removed the 1250 serial tag. Here it the correct serial tag for my 1450 that will be going on:
[/IMG]
That's all for now
Old 09-30-2017, 10:39 PM
Exclamation Man, I think I've figured it out!
So today, when I was removing the right front wheel, I had spun the wheel and noticed an awful noise, and it is just what I have been trying to figure out all along. Its the new inner wheel bearing! I'm going to set up the tooling and give a video spin and see for sure.
I wonder how this happened! Maybe I over tightened the rim to the spindle? IDK. This is for real. Laying in bed going through the manuals for my 1450 for the life of me and all of the sudden the light came on.
I hope this is it! Gonna pound out the bad bearing and install another. No chew marks on a perfect 1" spindle, however!
Later on guys!
Old 10-01-2017, 02:34 PM
Well, I got a bearing out of a back up front rim just fine with a little hear, and WD-40, hammer and punch. It's the exact bearing that I just put in new, in my new set of front rims. So, later I plan on changing out the bad one.
Today, is a great day to be outside, away from the crap on television! Prep and painting the last of the disk brake caliper components. Going to degrease and prep the front 1" spindles for paint too! Probably start a few touch-up spots on the 1450 frame while its clean.
I don't think I'm going to open up the hydro pump. I knew what I was hearing was a bad bearing, I just could not determine where between the engine loudness, and the intermittent "weird" sound.
Old 10-01-2017, 03:02 PM
John, I'm glad you found the source of the noise!
Not real sure how you mistook a front wheel bearing for a rear end noise, but glad you found it just the same.
