Old 04-10-2017, 04:40 PM
Clehmberg Clehmberg is offline
Did you do the axle squeeze and add new tie greaseable tie rod ends while you were at it?
what is the axle squeeze? where do I get greaseable tie rod ends?
Old 04-10-2017, 07:44 PM
twoton twoton is offline
Originally Posted by Clehmberg View Post
..... where do I get greaseable tie rod ends?
http://www.mcmaster.com/#
Tie rod ends #4444T931
Old 04-10-2017, 07:53 PM
Some good reading for you;
http://www.onlycubcadets.net/forum/s...096#post343096
Old 04-11-2017, 07:31 PM
Originally Posted by twoton View Post
it's been a while since I pulled the front axle but if I remember correctly it was very snug so I don't think anything needs to be done with it. unless you think I need to.
Old 04-11-2017, 07:40 PM
thank you for the link for the tie rod ends I will be getting some of those.
Old 04-11-2017, 08:05 PM
..... unless you think I need to.
If you're happy with it then I think you're all set!
Old 04-12-2017, 05:30 PM
What size of box scraper will my 1450 handle? I found this 4' for $250.00 but I don't know if it's to big for it.
Old 04-12-2017, 07:09 PM
Keep up the progress on the 1450, I would grab that box blade never seen one like that before, is it home made?
Up to 534 and counting...
Old 04-13-2017, 11:33 AM
its actually a ford 700 series with a home made roller welded to the back.
Old 04-13-2017, 11:35 AM
since its 4' long will my cub handle it?
Tags
1450 hydrostatic, cub cadet, custom, rebuild
