Old 04-03-2018, 08:44 AM
nnero nnero is offline
Finally getting to the 107 now. Its been a crazy winter. My mule drive bracket is off getting repaired. I have the hydro/rear end gasket on order along with the springs and pins for the control lever. Will be doing front wheel bearings this week, then tackle the gasket. I will also be ordering a new wiring "harness" when I do the the voltage regulator. The cables are getting corroded and I figure this will be a good time to do it. Front tires and seat will be last.
Question: I want to put an original style sediment bowl back on. Right now I have rubber fuel hoses with in-line filter. How would i go about this?
Thanks!
Cub Cadet 107
Old 04-03-2018, 09:11 AM
What's the rubber line hooked to where it comes out of the tank?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-03-2018, 09:50 AM
Remove what is on the tank and screw it to the outlet on the sediment bowl, then add a new line minus the filter.
What's a Cud Cadet 107 in your signature line?
Up to 534 and counting...
Old 04-03-2018, 02:27 PM
It looks like a barb fitting that the line slips on, like on a carb. Ill double check tonight
Oh my, cant believe I havent noticed that. I have the ruminant special edition haha.
Also, what is the correct fuel line size? Im not sure what i have is correct it looks cobbled together.
Cub Cadet 107
Old 04-03-2018, 03:12 PM
1/4" fuel line. Come on man..... It's just a sediment bowl and like 8" of fuel line. Surely, it isn't that hard to figure out. Don't mean to be gruff.... but this is really simple.
Old 04-03-2018, 07:20 PM
Well I just wanted to be sure before I order or drive somewhere to get stuff. I've seen the sediment bowls with brass lines as well and want to get all my ducks in a row with fittings and what not. My set up looks crappy and cobbed together right now which is what I'm trying to avoid.
Cub Cadet 107
Old 04-03-2018, 08:11 PM
Better call before you drive. Most places don't stock a sediment bowl that small. My local Napa store does, but everyone else has to order them in.
You can use a copper (not brass) fuel line. That's what a 107 originally had on it, but it's lots more expensive to piece together, and it's a PITA. A rubber line is easy, only requires two fitting and lasts years. Unless you're doing a factory correct restore, it isn't worth it in my opinion.
Old 04-03-2018, 08:41 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Copper is super easy. Heck I made lines to a remote engine oil filter with copper before. That was about 3 years ago the gay is still using it
1- 1200 in pieces
1- 1864 in pieces
Old 04-03-2018, 08:45 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It's not one of these "gays" is it?
Queen Of The Quietlines!
Old 04-03-2018, 08:53 PM
Rescue11's Avatar
Voice-to-text
1- 1200 in pieces
1- 1864 in pieces
