Old 08-22-2010, 11:34 PM
rlcyran's Avatar
rlcyran rlcyran is offline
Default Cylinder
I've got the angle cylinder mounted to the front blade. It's 1.50" bore x 7" stroke. The front quick connects are mounted too. I need to plumb the quick connects to the valve and make a couple hoses for the cylinder and then I'll be able to try it out.
Were did you purchase your cylinder from? and what pressure are you using to the cylinder?
Old 08-23-2010, 05:12 AM
IHinIN IHinIN is offline
I got the cylinder from work. It's an old used Parker cylinder that was being thrown out. The mounts on it were wrong so I had to cut them off and weld on the correct mount.
Old 08-23-2010, 10:47 PM
Darrell Darrell is offline
Hi Adam , I am really likin' the bracket you made for the clutch arm to pivot on , would you make another to sell ?? Thanks , Darrell
Old 08-23-2010, 10:52 PM
Good eye Darrell. I'm actually going to be making another one for my 126 so I'll try to make an extra one for you.
Old 08-23-2010, 11:08 PM
LMK on the price , i might take more than one.
dgnewell@centurytel.net
Old 08-24-2010, 10:36 AM
Mountain Heritage's Avatar
You do DARN FINE WORK! Very nice! You going to paint the new steel yellow to match the tractor or white?
You should be proud of that set up, lots of hard work went into it. Very much worth it though!!
Old 08-24-2010, 10:06 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Excellent work & craftsmanship Adam! Definatly professional grade stuff. I hope you don't mind if some of us use your projects as templates for something that we wish to do to our own Cubs. I'd like to do both the separate brake pedal/control & a hydraulic setup somewhat similiar to what you fabbed up on your 100. Not trying to be a copy-cat, but both were killer ideas. Thanks for all of the pictures & info.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 08-25-2010, 05:16 AM
Thanks. It was a lot of work but it will really pay off this winter plowing snow. I plan on painting everything yellow. Once I get everything painted and add the filter, this project will be done.
Old 08-25-2010, 05:19 AM
If you have any questions or need any dimensions feel free to ask. I'll help if I can.
Old 08-25-2010, 05:13 PM
cadetfarmer cadetfarmer is offline
Default steel lines
IHinIN;
Where, how, or what, did you use to come up with steel hydraulic lines?
Cadet Farmer
