Old 01-25-2018, 07:51 PM
IHinIN IHinIN is offline
I’ve made a few more pieces for the ‘bota.
A belly shield to protect the fuel filter and hoses and the vulnerable HST cooling fan.
A set of 3-point stabilizer links to replace the clumsy turnbuckles.
The last is a bucket level indicator that works at any height. I mainly wanted it for my pallet forks since they can’t be seen from the seat and the bucket has to be tilted down for them to be level.
Old 01-25-2018, 08:41 PM
Nice work Adam. Interesting indicator. We made a few that had a solid rod inside a stationary pipe that was painted to be able to see level.
Is that belly plate plexi glass?
Old 01-25-2018, 09:49 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Those little details seem minor, but, as I'm sure you know can greatly enhance the operating experience and longevity of the machine.
1- 1200 in pieces
1- 1864 in pieces
Old 01-25-2018, 10:20 PM
Thanks. The rod and tube style are only good for showing level with the bucket on the ground. Mine works at any height.
The belly plate is made from 1/4” lexan and a piece of welded wire trough that’s used for runways for wiring.
Old 01-26-2018, 06:32 AM
Looks good. I like the level indicator. This is my belly shield, 1/4" UHMW
Old 10-22-2019, 08:07 PM
I’ve made a few more pieces for the Kubota including a canopy that folds down for trailering and a frame that fits the 3-point that my bucket forks fit onto. I also added a receiver hitch to the frame for moving my trailer as well as using a hitch hauler as a carry-all. Instead of building a thumb, I ended up buying a universal thumb and slightly modifying it for a better fit. The latest thing I’m working on is adding dual rear hydraulic remotes. These will allow me to build a hydraulic thumb for the backhoe someday.
Old 12-15-2019, 07:36 PM
Looking good, Adam!
Old 12-16-2019, 04:54 AM
Thanks Allen.
I finished the rear hydraulic remotes setup other than painting.
File Type: jpg 6615EABB-9CA9-418C-95D7-2CD18599EABD.jpg (30.5 KB, 117 views)
Old 03-27-2020, 07:31 AM
I built a hydraulic thumb for my backhoe. This was the main reason I added the rear remotes to the tractor. No more climbing off the tractor to adjust the manual thumb I had before.
File Type: jpg F2492613-CBA0-44B1-83C5-ADA1EEECB41C.jpg (34.8 KB, 93 views)
File Type: jpg 47EC30AC-5B9C-438F-8593-180BE190408C.jpg (37.4 KB, 97 views)
Old 03-27-2020, 09:19 AM
SWEET!
