Old 12-12-2017, 12:30 PM
mortten mortten is offline
https://m.ebay.com/itm/Cub-Cadet-145...ss!44264!US!-1
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-12-2017, 01:20 PM
Chad126's Avatar
Chad126 Chad126 is offline
Originally Posted by Bluecub View Post
Ok one last thing lol. The 12hp I have did not come with the drive cup(?) and I don't think the I have will work properly on it. https://i.ebayimg.com/thumbs/images/...EGY/s-l225.jpg
This Is similar to the flywheel on the 10hp
https://m.ebay.com/itm/CASE-224-444-...28.m4335.l8656
And this is similar to the fly wheel on the 12jp. Can't find the right part anywhere so if anyone could point me in the right direction it would be greatly appreciated!
Is it a K301? Are you needing Drive Cup or Flywheel or both?
Either way:
https://www.partstree.com/parts/kohl...l-02110131263/
Bluecub Bluecub is offline
Looks like that one would work on my k241 but need one for k301, appreciate it though
Old 12-12-2017, 01:21 PM
I need just a drive cup for the k301
Old 12-12-2017, 01:25 PM
Chad126's Avatar
You can get the cup new at the link provided above. Or get one used from ebay by using the part number in the link or an updated version if one has replaced the original part number. here is a link for compatibiility.
https://www.partstree.com/parts/kohl...s/52-755-61-s/
Old 12-12-2017, 01:38 PM
All they have is kit for 115$ and I wouldn't even know if that would be what I need for this.
Old 12-12-2017, 01:51 PM
Chad126's Avatar
If you do not have one, then you need one. And if you have a K301, this is the one you need assuming nothing has been modified/changed (highly unlikely, but if I don't put in this disclaimer then that would surely be the case). I was able to locate several on ebay from $45 used-$130 new using the part number.
Old 12-12-2017, 01:56 PM
Which part number did you use? There is a a lot in the one link
Old 12-12-2017, 02:31 PM
Chad126's Avatar
you're killing me brother...
Go to item 41 as seen in the pic I've attached. The pic is small, but you should be able to use it as a "map" when opening the link. P/N should be 52 755 61-S
The "kit" just includes a washer (item 6 in the same link). Search for this part number on ebay, or google, and you should find several results. BUT do yourself a favor and give it a sanity check. Do the mounting holes line up as expected when you look at how it will mate up? Do you have the old one and does it look the same?
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 12-12-2017, 02:48 PM
I google that number and all I found were ones that look like they would work on the k241 but not the k301. The k301 does not have a spot for that pin that's on these drive cups, looks like it should bolted to the flywheel? I'll have to look at the engine again tomorrow lol
Tags
k241, k301, oil pan
