Old 12-30-2017, 05:26 AM
twoton twoton is offline
Originally Posted by Slycox View Post
.....best place for carb kits and parts?
Always check with our sponsors at the top of the page first.
Here is a list that I compiled;
http://www.onlycubcadets.net/forum/s...624#post390624
Old 12-30-2017, 10:22 AM
dodge trucker dodge trucker is offline
got a local small engine/mower shop that sells Kohler parts? Lots of machines of various brands used Kohler engines. That would be quickest way to get parts if they have in stock. If they have to order, then just as quick to order for yourself (and at that point maybe cheaper) from one of our sponsors.
I tend to buy a few of them, along with other common parts when I have to order parts, helps justify shipping costs and I have parts for next time ( I also work on quite a few machines, probably not worth ordering a bunch of extras if this is your only machine)
Old 12-30-2017, 10:25 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
As far as #1 goes if I can't find an IH dealer nearby where is the next best place for carb kits and parts?
Amazon, E-bay, sponsors here as mentioned. A Cub Cadet dealer or most local shops that service small engines should have them too. K series motors were used on ALOT of machines.
Search Kohler K Carb Kit.
Here's one
https://www.amazon.com/KOHLER-25-757.../dp/B0015MLUS8
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 12-30-2017, 03:40 PM
Slycox Slycox is offline
Thanks for the information, might get out and were on it today if I can. I'll let you know what I find.
Old 12-30-2017, 08:38 PM
Bob95065 Bob95065 is offline
Originally Posted by DeltaCub View Post
December 1974...Early production!
My 1450 was made January 1975. Close
Old 01-03-2018, 05:12 PM
Figure I'll post what here what I have found so far.
Went out and started looking at it. Turning the key nothing happens, no click nothing.
The starter turns over when 12v is applied, I haven't found the solenoid yet but I haven't dug to far yet.
I have read up on testing the coil and will be doing that once I get some time. As of right now that is where I am at. Any thoughts from the experts?
One other thing that I haven't search yet is it appears that there is constant power even with the key out. No change in volt meter and the lights come on. Is this normal?
With what I was told I'm leaning toward coil, but with the constant power etc wondering if maybe it could be ignition switch?
Old 01-03-2018, 05:22 PM
I'm not an expert so I'll keep quiet for now except to ask if you had the brake petal depressed when you turned the key?
Old 01-03-2018, 05:41 PM
You are more of an expert than I. And I tried both ways since I wasn't sure if there was a switch there or not.
Old 01-03-2018, 06:16 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Does it really have a volt meter? If so it should read zero volts with key off. Otherwise a PO installed it incorrectly.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 01-03-2018, 06:24 PM
jsoluna's Avatar
jsoluna jsoluna is offline
I also won't claim to be an expert by any means. I will add, however, that in addition to the brake switch, the PTO switch will interrupt the starting circuit. Make sure it is off and the brake pedal is depressed.
http://www.solunagarage.com
