#31
Did you set the float ?
#32
Condenser.
#33
It is beginning to sound more of an electrical issue. Wondering if its something odd like a damaged wire making poor/intermittent contact to the coil or to the points. You have done a lot to the fuel system, why not go over the ignition with a fine tooth comb as well. If this is to be a weekly mower it wouldn't be wasted time to replace anything in question as well as having peace of mind as to its condition.
#34
Not likely. He stated in post 1 that it would only run at WOT, and wouldn't run at lower speeds.
I'm leaning toward that "overhaul" the PO did..... I'd say the motor is junk. Valves probably sticking and bad, crank may have been galded and the cylinder worn out.... but he just stuck a new rod and piston in it, said it was fixed and sold it. I think you have multiple problems. Could still have carb issues..... it's not hard to clean a carb. Doesn't take 3 tries to get it done. If you've been over it that many times and it still isn't working, either you have no idea what you are doing or looking for, or there isn't anything wrong with it. I thought you said the guy who sold it to you was "looking for a carburetor" for it?? Not like those are hard to get. Tons of them on ebay. New ones for like $35. (Personally, I'd prefer the old carb, and just fix it if it has issues.) |
#35
It will consistency start after sitting and run between 5 and 45 seconds. It will usually start a second time and sometimes a third time.
This morning it started with the choke. I eased the choke off and when it began to die, I choked it again. This repeated maybe 5 times before it wouldn't stay running again.
147 w/ 42" deck w/ 3pt hitch all in memory of my grandpa's 124 |
#37
I think you should get rid of that. If your fuel tank, lines and sediment bowl are clean you don't need it and it can cause fuel flow problems.
#39
For those of you who have said you are interested in the outcome, here's an update:
As it turns out, the flow was fantastic but was continually changing as the mower ran... When I replaced the new seat in the carb, I was afraid of over-tightening to the point that it wasn't tight enough. It worked it's way loose which lowered the shut off pin. As you now probably have deducted, the float was shutting off the gas flow too soon, and the gas flow into the bowl. After sitting, it was slowly filling the bowl, allowing it to start again. Now to replace the deck belt that just broke. Thanks for your input guys. I'm sure I'll be back soon.
#40
I will take it out after I'm sure that the tank is clean. When I took the bowl off once, there was a tiny bit brown oily substance in the bowl. There's a tiny rust spot in the bottom of my tank so I'm gonna clean it again.
