#31
![]() No question need... Youtube is full of tutorial! Let me know wen I can upload this to your space.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#32
Ok, so this is kinda of an update, a rant, and a warning all in one LOL
So we ordered a new sliding rear window from LMC and a seal. The original was a flat non sliding window. We installed it Friday. Now usually these pop right in with a little soapy water and a piece of clothes line cord.. This one took multiple tries. It just felt too tight top and bottom and the sides on left and right kept ending up loose. Drove us nuts. when it finally went in the result is ugly. Left and right have visible gaps between window frame and rubber. You can almost see daylight through the gasket on both sides. I will be sending it back and trying another manufacturer.. Really poor craftsmanship on this window tho. Sad really. The gasket itself got a little beat up where it was too tight in the center top and bottom. We had the window partially in and out several times and rotated gasket a few times. The strange thing is there is no visible orientation for the gasket even tho the top left and right corners are substantially different radius's than the bottom left and right corners. Almost forgot the warning.. Be leery of CR Laurence products.. BAD FIT!
#33
#34
Just love on the website that they boast what a great fit their windows are.. After painting a truck the last thing you want to be doing is having a hard time getting a window in and out around fresh paint. I am looking for suggestions for a manufacturer of a sliding window for the 55 if anyone had had good results with a window company..
#35
One thing to check is how the frame fits the opening of the truck and you can do some grinding to fit. Check your rubber, what ever the cross section between truck and window is what you are looking for. Unless its the type of rubber that over laps, but I don't thing that truck is if I remember right. You can use some small strips of rubber to push the gasket into corners that are too loose. Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
#36
I see MIDFIFTY sells the same one. Now I am seeing they call it a "tight" fit. but then they show this picture. LOL.. Is there no quality in anything anymore. Sadly the picture on the the midfifty website shows exactly what I wound up with. ![]() How dare they even sell these pieces of crap! I know by seeing it installed in the truck now that its not of matter of will it leak " I know it will " its more a matter of when will it leak and destroy my new interior, sound system, etc.. Will I notice it right away? Or will it be moldy before I see it? Ughh.. might have to do away with the slider.. Thank god I have after market A/C in the truck tho
#37
I have been a glass man for 30 years and the problem is cars and trucks built back then were nowhere near precision built like they are today as I am sure you are well aware. The sliders are aftermarket quality and always have been. If you want a slider to fit nice, doing some work on it is the only way. I wouldn't grind on the body either, but you can grind on the corners of the slider and use 1/8" rubber cord to fill the gaps. The rubber gaskets are not what they used to be either.
I have cut the glass larger and use a molding from a later model to glue them in and look and little smoother too. Looks pretty good on some. Randy
#38
