Old 07-15-2010, 07:28 AM
22Power 22Power is offline
Thanks guys. I have been racing this week, I will be back at this project this weekend. I have a complete cast rearend with axles and pump that i am going to use for the tractor. I want the strenght and needed a new pump. i will bolt that in and see if we still have issues.
I plan on welding the holes shut in the back and then redrilling them eliminate the wallered holes,
brett
Old 07-18-2010, 10:35 PM
All-
The problem is solved on why the cub leans to one side and feels so spongy. the aluminum casting just above both side bolts on the rear on the tractor is broken.
I removed the fuel tank today and ther it was plain as day why it moves.
Old 07-18-2010, 10:46 PM
Glad you found the problem. How hard is it going to be to fix? Keep us posted.
Old 07-19-2010, 01:49 AM
dross dross is offline
Default rear end
If you bent a spindle it would hang one side of the axle lower but if the pivot pin isn't froze thats all it would do.
