Old 09-24-2018, 05:05 PM
Chad126's Avatar
Chad126 Chad126 is offline
Jon,
I can say that there a few here that can match your knowledge. However, your people skills are a bit under range. No offense intended. I feel that you are aware of this already and quite honestly, sometimes I find myself literally laughing out loud as I read some of your comments that are rude, but entertaining. I'm not saying that what you are writing isn't true at times, but some things are better left unsaid.
Again, no offense intended because I can relate. About 4 years ago, my employer sent me to some training in our area that was titled "How to Communicate with Diplomacy and Tact". I asked why I was being sent to this training, and was told that I could use a bit of help in delivering the truth to some of my fellow employees. Apparently everyone at work thought that I could be an asshole at times.
Long story short, I didn't learn much from the class itself, but I did become much more aware of my situation, and I have tried to be more cordial ever since. You are an intelligent fellow, and many folks who have intelligence often lack patience with people who don't understand what they do. Just see it as your job to teach them and that you are doing what coop said, and helping bring one more cub back to life. After all, that is what we all have in common.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 09-24-2018, 06:22 PM
sawdustdad's Avatar
Tim338,
Tell us a bit about yourself--your skills and experience level. That will help us provide meaningful support. Based on your effort to replace the wiring harness, it would seem you've got some experience with this stuff?
Old 09-24-2018, 07:45 PM
Tim338 Tim338 is offline
Hey I'm fine. I have thick skin so no worrys. I have been lurking on this site for sometime and I really enjoy it. Thanks everyone for making me feel welcome.
Originally Posted by bllwnkl View Post
Tim338,
Try to let it go. These guys are a lot of help but sometimes you have to overlook some stuff that was said. But if they suggest something and you don't try it, they are less likely to offer help the next time. I don't know what I would do if not or this forum. They've helped me get through some predicaments and taught me a lot. I feel like I have new friends since I've been on here.
Old 09-24-2018, 08:12 PM
Well, what, if anything, have you found or discovered...???
Old 09-24-2018, 09:18 PM
It will probably be the weekend before I get a chance to look at it again. About myself. I love old iron. I have a really nice metal shop with a lathe, mill and know how to use them well. I love to tinker in my spare time I got the cub 72 for free it had sat in a barn for the past 23 yrs. I replaced the head gasket, points, plug, condenser, plug wire, coil, rebuilt the carb and replaced the muffler. I found a nice set of fenders and found the right seat for it. I had it running great until the harness swap but I'll get it figured out. Also the cub came with a 38" mowing deck that is in great shape.
Old 09-30-2018, 12:11 PM
Small update... I traced all wires in harness and everything was hooked up right except solenoid. Hooked that up right and still nothing. I jumped the solenoid by running wire to positive side of battery to the small post on solenoid and it turned over and started. Might be a dumb question does this mean my solenoid is bad? OR could it mean the keyed starter switch is bad? I welcome any input.
Old 09-30-2018, 12:18 PM
You will have to trace the start path from the key switch through the clutch brake switch to the solenoid coil (small post on solenoid) There’s only 3 wires on the keyswitch. Battery in, run out to ignition coil, and start. Do you have a meter or a test light to verify?
Old 09-30-2018, 12:19 PM
cooperino's Avatar
To figure out which it is. Use a test light and see if you get voltage during crank... or you do not it could be keyswitch or associated wiring
Alvy posted same time...
Old 09-30-2018, 03:33 PM
So in the start position I should have 12v going into the clutch switch and with the clutch in the down position it should pass the 12v to the small post on the solenoid right? If there isnt 12v on the start side then its the switch right? Sorry for all the questions, wiring is my weakness.
Old 09-30-2018, 03:40 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Yep, should have 12V to the small terminal. You can test this by disconnecting (to be safe) the connected small wire, then jumping 12V from the 12V battery post to the small post on the solenoid. With the switch in the ON position it should crank and start. I think* this is what you did , and it worked.
Before blaming the switch (which is what it's sounding more like) make sure that the connections to the switch itself are good (pull 'em off, make sure you can read voltage in the connector housing. If so, seat and reseat the connections a bunch of times to make sure that they are mating well.
Bypass the clutch connection for the time being too...make sure THAT is not causing you problems.
We're all assuming you have a test light or a DC Voltmeter ....... do you?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
