Old 10-14-2018, 08:58 AM
jbrewer's Avatar
jbrewer jbrewer is offline
That 100 will be very nice with some soap and water and about an hours time.
Still has dealer tag too.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-14-2018, 09:02 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Get that 100. Put the ags on the correct way before my OCD consumes me.
I didn't asked, but maybe only the reverse gear works!
Old 10-14-2018, 09:57 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Easy fix.....take the tires off and turn the tractor around.
Plow blade
#2 Cart
QA36 snowthower
Old 10-14-2018, 08:51 PM
Man, you ain't kidding. Drives me nuts seeing that.
I saw a Cub Cadet puller for sale on the local CL that had ags on backwards. I emailed the seller to tell him the tires were on backwards.
He was quite firm ( ok, he was a real d!c%head) that it pulled better that way.
There are some farmer that put them on backward on combines to get out on soft ground but I've never seen it on tractors
Old 10-14-2018, 09:45 PM
john hall's Avatar
Maybe there was a soft spot in the track where everyone else was spinning out and he was able to float on through!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-15-2018, 12:13 PM
I'd also rather have the 100, Terry!
Old 10-17-2018, 06:59 AM
T-Mo's Avatar
I brought the 100 home last night. I got it for half the asking price, but it does have some issues. They said it last ran last year to move snow. Ad said it needed a "car" battery, but the cable ends are regular L&G battery type. I was concerned about the muffler pointing up and being left outside, but he said it was always covered with a tarp. I checked the oil and it looked fine, and not too dirty. He said it needed a coil, but it may be points, condenser, etc.
It wouldn't start nor even crank over. Maybe the starter/generator froze up, but I have to suspect the worst - seized engine? But it could be something a lot less serious or expensive.
It came with the front blade and the original operator's manual for the tractor. He said it had a deck, but it was shot. It was their dads tractor and from what I gather their dad bought it new. I pointed out the ags being on backwards, and they said that's the way it's always been. He said I wasn't the first to point that out either.
It's home, but I haven't had the time to take it off the trailer yet. It was dark when I got home and I had to get up at 3 this morning.
Old 10-17-2018, 07:45 AM
cooperino's Avatar
If you put one tire going each direction that would give you the best traction in for forward and reverse no?? LOL
Old 10-17-2018, 12:40 PM
Congrats on the 100, Terry!
Old 10-18-2018, 07:06 AM
T-Mo's Avatar
Good news and bad news. I loosen the belt to the S/G to see which was locked up, the S/G or the engine. It was the engine....I pulled the plug and it isn't looking too good. I see rust on top of the piston and the plug was weird looking. All I had was a bit of motor oil, so I put a little straight through the plug hole and the engine turned just a tiny bit. I will get something a bit stronger, maybe transmission fluid, and pour a bit of that in and let it sit for a spell. Good news, the S/G isn't seized up. So, there's that.
I took some pictures before I got it off the trailer. It still has the original dealers tag on it. I haven't check the serial number yet to see what year it is.
