Old 01-01-2019, 09:51 PM
athomas's Avatar
athomas athomas is offline
I've had similar issues and looked at and changed every part you talked about nothing helped till I put a different plug wire on it , would let it run at idle and part throttle but crap out above half throttle ! just a thought
Old 01-01-2019, 10:19 PM
sorner's Avatar
sorner sorner is offline
I tried another plug wire already. Forgot to mention that... I didn’t open the points cover yet. Maybe I should check that too and see how the points look. Thanks for the ideas guys.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 01-02-2019, 10:56 PM
sorner's Avatar
Well I swapped the condenser, replaced the points (they looked pretty bad) and thought I found the problem because the points were rusty looking. Still the same issue. So I went back to the fuel system. Pulled everything back apart. I found a piece of rubber stuck in the outlet hole of the sediment bowl. It came from the fuel line fitting I think. So I’m going to have to replace that, and then I think I’ll be good to go. It allowed fuel to come through but I think it blocked it enough to be a problem. There’s nothing else it can be. I’m either going to replace those fittings or switch to a petcock and soft fuel line. In other news, the drive shaft has a wobble in it when the engine runs, and it causes a vibration. So once the engine is resolved I will have to move on to the drivetrain.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-03-2019, 11:08 AM
Good to hear you got it running, those rubber sleeves tend to fall apart and cause your issue...
Old 01-03-2019, 11:10 AM
sorner's Avatar
Don't jump ahead... it's not running yet, I need to pick up some supplies to rebuild the fuel delivery system. Though, I'm pretty confident you'll be correct in that I got it running.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-04-2019, 09:12 PM
sorner's Avatar
Problem solved. She runs great now and does not stall!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-04-2019, 10:27 PM
DieselDoctor's Avatar
Old 01-05-2019, 06:14 AM
twoton twoton is offline
Good to hear.
Old 01-05-2019, 04:14 PM
CubDieselFan's Avatar
Awesome, now to repair the drivetrain.
Old 01-05-2019, 11:12 PM
sorner's Avatar
Ewww. Looks like I’ll be hitting up Jeff for some parts.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
