Old 01-11-2020, 08:55 AM
Nato527 Nato527 is offline
I’ve got another question that’s got me stumped. Why does this 10 horse have a wrap around heat shield and my 12 horse have a short one? My 125 has a replacement engine , so I thought that was the answer. But then I found this 10 horse on eBay, original engine, short heat shield. The reason I’m asking is because when taking parts off the 10 horse, it seemed like everything on the exhaust side of the motor had gotten hot at some point. Points wire and coil wire were baked and brittle. Head bolts on that side were really hard to remove etc... should I find a short shield or is it something I’m putting way to much thought into?
File Type: jpg D2B0719A-941F-4022-BDB4-85A777A22A64.jpg (23.4 KB, 83 views)
File Type: jpg 5EF9FFA5-513F-4C36-87D3-84293CC3FC52.jpg (32.5 KB, 83 views)
Nate
Old 01-11-2020, 07:37 PM
Every thing is yellow now! Got it done early this morning,been throwing the heat to it all day. Hopefully will be able to put some pieces together tomorrow.
Nate
Old 01-12-2020, 02:57 PM
AndrewNoyes AndrewNoyes is offline
That's really looking nice.
Old 01-12-2020, 03:43 PM
Thank you. Got at it early this morning, and then I found this! Can’t believe I forgot to paint the tank.... it was wrapped up in a towel in the corner.
Nate
Old 01-12-2020, 03:45 PM
Guess I’ll hit it when I do the white, just sucks having to clean the gun twice...
File Type: jpg 07589C74-2E2A-47E5-A4A6-5D2E17981865.jpg (21.6 KB, 61 views)
Nate
Old 01-12-2020, 06:38 PM
I did save myself 80 bucks for a drive hub. Just welded it up, and cut out the slot with a grinder. Should work for a bit.
File Type: jpg 5B854DDC-43CE-4C02-A192-A98D96C00DCA.jpg (22.1 KB, 56 views)
File Type: jpg D3055AD7-340E-4F1F-A82A-A3DE2A8849BB.jpg (29.7 KB, 57 views)
Nate
Old 01-12-2020, 07:29 PM
modcub72's Avatar
modcub72 modcub72 is offline
Loooooookingood!
Change your oil as soon as you can,
and often.
Sand blasting the engine like that will have sand finding its way in.
Don't ask me how I know.
Regardless, you're doing a damn good job.
Old 01-12-2020, 07:33 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Looking good Nate!
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 01-12-2020, 07:51 PM
IHCubCadet147's Avatar
Looks good!
Old 01-13-2020, 12:17 AM
Thanks again everyone. Very good advice on changing the oil, I didn’t sandblast anything, that’s just primer after a once over with the old wire wheel.
Nate
