Old 03-29-2020, 10:13 AM
pinehillian's Avatar
pinehillian pinehillian is offline
thanx, they were exelant photos, mine must be correct. im thinking with shafts out packin them with grease around lower bearing then adjusting flat down alittle, i only have about 1/8in of threads on top. see how it goes
Old 03-29-2020, 03:54 PM
think im good now getting ready 2 put deck back in, 1 more quest is i had a 48in 3 blade on my last rider (craftsman) and put blades on all same position and noticed vibration. i moved 1 blade and all good. does my 50in gt cub deck have any kind of certain position for blades before i put deck back in (-10clock-12clock 4oclock?) thanx
Old 03-30-2020, 07:00 AM
bugeye bugeye is offline
I have the same 48" mower deck. I loosen the blade nut before I grease the spindles. Same on my 54" deck. I do get the grease exiting under the deck during operation as evidenced by a smear when I remove the blades. It is not like greasing the deck wheels where the grease oozes as it is pumped into the zerk.
I do not orientate the blades in any manner. When I sharpen the blades, I check and correct the blade balance on a cheap cone/point balance device.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
