Closed Thread
Old 10-04-2021, 09:41 AM
EternalArianne EternalArianne is offline
Yeah it's looking like I'll hafta order online as most of the stores around here only carry 3/4" PRV and my lines are 1/2". I was hoping to get away without an expansion tank due to costs, I guess I'll see how it goes after installing the PRV I can always add one later if the pressure is still an issue.
Either way this will be waaaaay cheaper than the estimates I got for replacing the water heater via a plumber. They all wanted $2K+ and so far I'm only $550 into it...
  #32
Old 10-09-2021, 07:16 PM
Slight update - the main line coming from the street is 1/2" PVC but all the PRVs I can find are "sharkbite" which is CPVC/copper/PEX. CPVC and PVC are NOT the same diameter so they aren't interchangable. After talking with the plumbing guy at Home Depot (who actually ended up being an old high school friend I'd lost touch with), I'm using a sharkbite adapter from 1/2" PVC to 1/2" PEX then using a 1/2" PRV, then back to 1/2" PVC using the adapter again. The internal diameter between PVC and PEX isn't too much of a difference so hopefully it affect the pressure too much.
It's gonna look funky as hell but it should fix all my problems (hopefully)...
Closed Thread
