#31
Got the china carb dialed right in tonight after the throttle linkage bushing arrived. Runs and drives great. Also installed the sleeve hitch (minus the lift bar) and changed the hydraulic filter (was planning on doing fluid, but it had spotless hytran).
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#32
I see yours also has the iron rear.
Here is another early CCC- A 682.. 700912 Has the yellow dash tower, International dash, and Brownsville tag.. https://******************/marketpla...0272383627574/ https://******************/marketpla...0272383627574/
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#33
#34
Apparently, the board has an automatic f. acebook filter... I hate f. acebook too, but come on....
#35
#36
Rear tires look good. Pressure washed again, and put all the tin back on. Spread lime with it last night around the walnut trees. Runs like a top, and according to the wacky hour meter is under 300 (I'd assume that to be on the new engine, not total).
#37
Thats a nice tail..
#38
Thanks. It'll look better w/ the Brinly adapter and cultivator on there. Jeff had some part shortages but hoped to ship today.
#39
Can anyone make hood stripes for the CCC 782? I only see the IH version on eBay, and none available from CC. The P/N their site lists is 759-3153 which is not accurate from what I can tell.
Here's my 984's for reference. Should be just like a 982/1711 style, but with 782.
#40
