Old 10-03-2022, 04:20 PM
Farmall450's Avatar
Originally Posted by Radioguy41 View Post
I cut down the lift bar and it now clears the pin. I hung the sleeve hitch assembly and as soon as it stops raining I'll hang the rock rake on it and see how she works. Thanks for all the suggestions guys.
Perfect. I agree that this is the simplest path forward.
Old 10-03-2022, 05:20 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Thanks, yeah, still waiting for this cotton picking rain to go away so I can try it out.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 10-06-2022, 04:37 PM
Radioguy41's Avatar
At last, sunshine! Had the opportunity to work the rake today and the only questions is,,,, why did I wait so long to get one of these rigs!? Love this thing. What used to take up to 2 days hand raking was done in less than an hour.
The only bit of an issue was I'm used to the Farmall Cub's hydraulics in that there are adjustable stops to set limits on how high or low you want the lift to go and the CC is lacking that so trying to set the rake at the same height on each pass took some trial and error with imperfect results but I got better at it as time went on. Anybody ever come up with a depth control for one of these? Maybe something back at the hitch?
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 10-06-2022, 04:44 PM
Radioguy41's Avatar
I also wanted to see if there was going to be any issue using the drawbar while the hitch was attached so I hooked up the mini-haywagon and took it for a spin, No problem between the wagon tongue and the hitch.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 10-06-2022, 08:49 PM
That little knob on th right takes care of setting the height.
Up to 534 and counting...
Old 10-06-2022, 09:01 PM
Radioguy41's Avatar
Hmmm, forgot about that. I'll have to give it a try. It's been a rough 48 hours. We took a lightning strike on Tuesday and it took out a lot of electronic gear. I've been pulling my hair out trying to recover and restore what I can so things are a little foggy.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 10-09-2022, 10:20 PM
Farmall450's Avatar
Ditto.
I do have a hard time with how responsive the hydraulics are vs most 3 points, like my IH 284 or the neighbor's B-series Kubota.
