#31
I got the cylinder changed out yesterday. Simple and straight-forward. I did fill the new cylinder before installing. Once it was together, I started the engine and cycled the steering a few times. Then I took it for a short test drive. It worked right away.
![]() I'll do the 1864 next. I need to do one more mowing before the grass gives up. |
#32
Nice to know, good job Rex.
#33
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
#34
#35
You guys have inspired me, I need to clean the carb on my 1862 so that I can blow snow with it this winter. Never going back to a manual steer tractor with a snow blower
I just skipped it all together last year! Ran great in the spring, floods in the fall. Will fun for a min or so with the fuel pump unhooked, so I think the float is probably stuck.
