Old 03-01-2025, 10:39 PM
There is a difference.
The drive shaft is 18.19" long,
From the front,
First hole is, 1.125" (front plate)
Second hole, 2.255 (rear plate)
Third hole 9.250" (tension spring)
Forth Hole, 13.250" (rear coupling creeper)
Fifth Hole 17.9375" (rear coupling no creeper)
Up to 534 and counting...
Old 03-02-2025, 09:35 AM
A creeper is not needed for a moldboard plow.
Speed is your friend when you are plowing a garden.
2nd gear works well.
Plowing up sod?? Well then, all bets are off as it is a real PITA, even with a tiller! You will wish you hadn't even tried.
Same for plowing snow, Hammer down, roll that white crap off the blade and outta the way!! Just be sure you KNOW what's under the stuff and don't hit a curb box or high spot or you WILL Break something!!
Old 03-03-2025, 08:01 AM
Jamocha Jamocha is offline
I plan on getting a tiller.
Old 03-03-2025, 08:54 AM
A tiller will want to PUSH the tractor big time if the ground is hard and packed and if you are tilling too deep.
I usually fall plow and then till in the spring for best results in my garden plots.
Plan on close to 1000 hills of potatoes this year.
Old 03-05-2025, 12:24 PM
From the front,
So if I am understanding this correctly I should cut the shaft somewhere around 13.5-14"?
Old 03-05-2025, 02:05 PM
If it is an original shaft, it should be scored where it is supposed to be cut for a creeper installation.
Old 03-05-2025, 02:54 PM
I did not see the line the first time I was messing with it. I'll double check but I doubt its the original
