Old 08-04-2018, 04:08 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Log puller
I used the 1250 to pull this big log to a spot in the yard. I put reflective house numbers on the log and turned it up on it's side.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 08-04-2018, 07:53 PM
Nice work, I had a big rock in front of my house and did the same, what is that white stuff?
Up to 534 and counting...
Old 08-04-2018, 08:43 PM
IHCubCadet147's Avatar
Looks good, except I cannot read the numbers
Old 08-04-2018, 09:09 PM
bllwnkl's Avatar
I think I got them too close together!
Randy
Old 08-04-2018, 09:13 PM
bllwnkl's Avatar
White out!
No, I just "painted" over the number on the picture before I posted it.
Randy
Old 08-04-2018, 09:21 PM
cooperino's Avatar
Don't want us knowing your house number huh HAHAHA
Old 08-04-2018, 10:17 PM
bllwnkl's Avatar
Well, what can I say?
Randy
Old 08-05-2018, 07:48 AM
john hall's Avatar
That we aren't invited over for supper
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-05-2018, 02:35 PM
bllwnkl's Avatar
Nor anyone else for that matter!
Information is getting to easy spread now a days. Just don't want the wrong people trying to get to us.
Randy
Old 08-06-2018, 08:04 AM
cooperino's Avatar
So yesterday I wanted to cut the back yard with one of the 129's. I had already cut the front with the 1211 and figured give each tractor some use. I started up the 129 and happened to notice the amp meter acting erratically.
A couple of quick tests showed I was not charging and the S/G was good. I removed the V/R and opened it up to find the feed to coil was burned in the middle and broken.
This is the first time I have seen one do this. I soldered the wire back together and tested the continuity. Replaced the V/R and its now charging fine. I shut the tractor off for a few min to tighten everything up. Went to restart and it would not start. No spark. I checked everything out and found the coil took a crap. I had the battery disconnected while the V/R was out and don't think I shorted anything. I put a another coil on it and everything was fine after that.. Maybe just a fluke I guess.
Anyway, Point of the story is maybe not a bad idea to pop open the V/R's and have a look before buying a new one. I will however order a new one and keep the repaired one as a back up.
The repair is not great.. Only had some solder that was thicker than I really wanted to use. Ugly but it works!
