Old 03-04-2012, 09:15 PM
Sounds like a good deal mharrison
Old 03-04-2012, 10:42 PM
I'm with, Diz! You did very well.
Old 03-05-2012, 05:57 PM
dieseldan123's Avatar
Today i put my 3pt hitch, suitcase weights and bracket on the 108, hooked up the box blade and did some driveway leveling! Ill need a spring assist if i keep using this thing, but had a great time working the cub anyway.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 03-05-2012, 06:28 PM
dieseldan123
Nice setup, the suitcase weights look cool on the front
Old 03-05-2012, 06:54 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Nice job!
Man, work sure gets in the way of some good hobbies!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-05-2012, 07:12 PM
Nice job!
John
Thanks Diz!
John you got that right!
Old 03-05-2012, 10:53 PM
ihnick's Avatar
ihnick ihnick is offline
Stopped at the local metal shop today and picked up my parts. I got a top link for my back blade made and a new top for my cap project made. The best part was that he only charged 20 bucks!!! So then tonight I worked on fitting the cap on the 108. The front is mounted and the top is ready. I just need to trim som on the back and find a way to mount it wihout drilling the fenders. So here's what I came up with today
Nick.
Old 03-06-2012, 02:12 AM
Looks great Nick!
Old 03-06-2012, 11:21 AM
Thanks for the nice pics, guys!
Old 03-06-2012, 07:15 PM
cub123's Avatar
cub123 cub123 is offline
Did quite a bit on the O today, tightened the drive belt, while I was under it I noticed the steering box was loose. So out comes the battery and steering wheel,and the dash tower. Since I had it that far I wondered how old that grease is so out with the steering box! Well it was 50 year old grease but the box,follower pin, and bearings are perfect! Just needed is a good cleaning and new grease No slop in the steering now! Also figured out my carb leak,the bowl had a tiny pin hole in it, replaced it. Then I took the shifter cover off to check it out, clean oil and zero rust or water in it. It was a good day
