Old 03-06-2012, 09:03 PM
MrGitrdone41's Avatar
I got my rebuild kit in yesterday in the mail. I started to rebuild the motor out of my 128. I got alot of it done but i don't have a valve spring compressere so i can't put in the valve yet. I can't wait to fire it up for the first time! Than a plow day with my friend!!
1988 1812,dual ports
1973 108
1968 125
Old 03-06-2012, 09:24 PM
I use a spring compressor that you can find at any auto parts store. It is designed to compress those door springs that was used in those 80's vehicles. Think they might run about $10.
Old 03-06-2012, 09:29 PM
Thanks Dwayne! I'll try that.
1973 108
1968 125
Old 03-06-2012, 09:37 PM
You got a pic of that thing Dwayne?
Old 03-06-2012, 10:00 PM
Did quite a bit on the O today, tightened the drive belt, while I was under it I noticed the steering box was loose. So out comes the battery and steering wheel,and the dash tower. Since I had it that far I wondered how old that grease is so out with the steering box! Well it was 50 year old grease but the box,follower pin, and bearings are perfect! Just needed is a good cleaning and new grease No slop in the steering now! Also figured out my carb leak,the bowl had a tiny pin hole in it, replaced it. Then I took the shifter cover off to check it out, clean oil and zero rust or water in it. It was a good day
Sounds like a great day to me!
Awesome news Sam!
Old 03-06-2012, 10:34 PM
Yep, found a pic on google:
Old 03-06-2012, 11:27 PM
maddog784's Avatar
My grandpa said that when he had to compress a valve spring without a tool, he put a couple pieces of wire through it, then compressed the spring in a vice. When it was compressed, he would tie the wires so that they held the spring closed. Install spring, clip wires, pull out wires, done. I call it the poor mans' way.
Cheers
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-06-2012, 11:37 PM
You guys have been busy!
Old 03-07-2012, 01:03 AM
HotDawg Cubs HotDawg Cubs is offline
Cheers
Nate
HausFraus mend things that way, too!!!
Old 03-07-2012, 02:45 PM
Attachment 21936
Cool! Thanks Dwayne!
