Old 08-03-2016, 02:46 PM
gcrv1811 gcrv1811 is offline
So... I have been working away from home on 7 12s for the past couple months which doesn't leave much time, none, to work on my projects. I hope to get back at it again soon!
Just found out though that the 1811's mower deck is only cutting on one side. I haven't been able to check it out myself (see above) but I want to go ahead and order new belts that I can install when I get back. Anyone know what I will need to order for a 44 inch deck?
Old 08-27-2016, 11:08 AM
Bump. Looking to order some parts today. Any help would be appreciated.
Old 08-27-2016, 01:03 PM
CubDieselFan's Avatar
Should be able to look up the part number on Cub Cadets web site. Look under parts and service.
Old 08-27-2016, 02:12 PM
Yes, this is correct. Look up the parts yourself. Very easy to do. Follow the prompts.
If it is only cutting on one side, you better look before you order parts. No way that the blade on only one side is spinning. Check to see that you (or whoever) didn't install a blade upside down. Also make sure all the blade spindles will turn by hand (engine off). If the deck drive belt was broken, the center blade would be the only one spinning, not an outside one.
