#41
Looks good! Your going to love that tractor
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. |
#42
Looking good! You are making great progress!
1772's rule! |
#43
Awesome progress on your 1772! Thanks for the update.
#44
Good to hear from you! Thanks for the pics.
#45
Red, depending on the fund$, here are some options.
On the battery - I just use a good Deka L&G one and get a tender for it. The exhaust - I got 2 complete ones off of Evilbay, one was $165 and the other was $200 to my door. Be careful on used ones because the ones I replaced were not passing enough exhaust and loading the motor up. This is a good seat for the money but you will have to drill it to fit. http://www.surpluscenter.com/item.as...atname=engines Some say they run cooler without the side panels but I think they look better in place. I'm always looking for SGT cat 0's and the ones I see on Evilbay and others are crazy high. I got my Ruegg shipped to my door for $462. Look at the one Cub123 just installed. If it doesn't have to be correct there is a guy in NC that makes the GT cat 0's for around $350 + shipping. On the radiator, It explains how it is attached in the 82-72 service manual on page 1-21. If you need that manual send me your email or it may be available in the tech section. Keep up the good work! Your doing a great job so far.
#46
If the 982 had a cast iron rear, you'll need a different rear cover plate with the stud for the belt idler, or modify the existing one you have.
#47
You will have one like in the first pic from the 982 but will need one like the second for the aluminum rear. I may be able to trade rear covers once you get yours and you need a different one. That would be a killer deal if he has it for that much.
#48
72....I don't like the cold either, that's why I moved south. I never thought about a dry cell batt but it sounds like a good idea and I will check on the next one I need. I just use a good $50 Deka and a tender and don't have any problems. Can you get those at a regular batt supply store? I was just letting him know that you don't need a gigantic batt in a diesel like some people think.
#50
Nice score on the 3 point and rear pto!
