#41
Man do I know how that goes. It's only X amount for this and that and then you add it all up.......... BTDT. If you need or want a Vanguard 16HP I have one out of a Cub that I just fixed up and got running. If I'm smart I'll sell the engine rather that start another project. LMAO
#42
I agree.
#44
went "picking" in my pile, found a muffler, an air cleaner, gas tank, wide front wheels and tires, brake pads, a QL front grill casting and nose piece. No ignition switch, however, the one on the 147 parts tractor was trash.
Need a pair of iso mount rails and a hood. Will put an ad in the wanted section.
Went on ebay and bought an ignition switch, and tunnel cover. Slowly accumulating parts...hoods are $100 or more with shipping! Yikes!
Give Cub-N-It a shout, I think he may have a set of rails for a QL
#47
Lew's offered me a set reasonable.
Picked up the hydro today, steering column and gear, steering wheel, and a driveshaft. I think I can start putting this puppy together. Need to do some cleaning of the frame, look at what needs primer/paint. Pics to follow.
Looking forward to your pics.
#50
Some pics of the replacement hydro unit (pretty dirty, I must say) before and after some cleaning. The trunnion is badly worn, so I took the trunnion from the damaged hydro and did the repair using the replacement part. some of the other parts I've got lined up, including the rebuilt engine. I ordered seals and gaskets for the hydro. I plan to open it to check it out, do any cleaning, replace the trunnion arm and reassemble. And, finally, the chassis as it sits. Note: I put the blue paper towel under the trunnion for picture clarity.
