Old 12-07-2014, 07:48 PM
Here are some other filter numbers for you.
NAPA oil filter 1064
NAPA air filter 6270
NAPA hyd filter 1410
If you find that you need to get into other areas like the trans or need to replace things like hose's or the fan belt let me know, I have the numbers in my file.
Old 12-07-2014, 11:23 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Thank You so much for the info. I installed the new hydro filter and the oil looked ok for now. I don't have a battery yet so I hooked up jumper cables to my daughters Original and gave it a try, 3 short cranks later and she's alive!! 3-point goes up and down and the tractor moves foreward and backward. Front and rear Pto seemed to work also. I can't believe how smooth and quiet it runs. This gas Kubota sounds verry similar to my diesel Kubota in my 882. I love the way it sounds and it is verry quiet also. The steering is super quick and super easy to turn. I think I'm gona love this new to me machine!
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 12-07-2014, 11:36 PM
Glad you got it running!be sure to check out the bolts on the rear.
Up to 530 and counting...
Old 12-08-2014, 07:05 AM
Put the two of them side by side and take a close look at both engines. Glad you got it running sounds like you have a winner.
Old 12-08-2014, 07:45 PM
PaulF PaulF is offline
Great looking Cub...gotta admit I had no idea there was a Kubota gas engine.
Anyhow I just joined the site, and lo and behold, we only live a couple minutes apart! Drop me a line if you'd like to chat Cub Cadet some time.
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 12-08-2014, 09:31 PM
cubfan's Avatar
cubfan cubfan is offline
Some people have all the luck.That cleaned up so good.Doggonit,some day I hope I can be in the right place at the right time.
Old 12-09-2014, 02:49 PM
Thanks for all the comments. Last night I topped off the hydro fluid and did a temperary rig job with a battery from my 882 and started the 2182. Cold start, no choke (choke cable is seized) 75 degrees in my shop and it started with only a 1/2 second touch of the keyswitch. I'm verry happy with the way this thing runs!! Tonight I will have the fenders off and install a new trunion spring setup. The small spring and one end cap is missing at this time. I will be installing the stiffer trunion spring that is an exhaust spring from the help section that I found info about on this site. More pics tonight.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 12-09-2014, 05:53 PM
What is this "upgraded exhaust spring" your talking about?
Old 12-09-2014, 07:54 PM
Sorry I worded that wrong I fixed it. Someone here I believe came up with the idea You can use a spring from the help section at the auto part store. It is an exhaust manifold spring Help part number 03107. It is stiffer than the original trunion spring and it should give a better response to your travel lever. I'm going to give it a try tonight and see if it works well.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 12-09-2014, 08:02 PM
Yep got the spring idea from J-Mech, I did that on the 2182 I'm working on. Looks like it will work just fine.
