Old 05-02-2023, 06:41 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Talking
Originally Posted by Radioguy41 View Post
I'm not entirely familiar with the specific wiring on this CC but to me red means hot and black means ground so when I see a red wire plugged into a black wire it makes me wonder if that's the way it's supposed to be?
This is a industry standard, but I have encountered a few red main ground cables on IH and early CCC Cubs. Why they did that is beyond me.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-04-2023, 01:50 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by malibulvr View Post
So the ignition switch HDK-152 and diode is 1N5400. I can get the tractor to run now but only if the red wire to the voltage regulator is not attached. Once I plug that wire in, the fuse blows.
The switch is correct and diode is correct....
The V/R takes a/c input voltage voltage produced by the engines alternator and changes it to d/c output voltage to keep the battery charged.
The a/c goes in on the two yellow wires at approximately 35 volts.
The d/c comes out on the red wire ideally 13-14 volts.
So, disconnect the red lead from the V/R.
Get out you DVOM, set your function switch to measure DC voltage (200 volt range) and connect the DVOM red lead to the red wire coming out of the V/R.
Connect the DVOM black lead to battery neg. terminal or a good clean ground on the engine.
Start your engine. Do you see any voltage on the meter.
Old 05-04-2023, 03:49 PM
RLause's Avatar
RLause RLause is offline
Sounds to me like a shorted regulator. Do a resistance check from the output of the regulator to ground.
Richard
Old 05-04-2023, 10:39 PM
malibulvr malibulvr is offline
It's entirely possible that you have a bad voltage regulator. I don't like the B&S regulators, I replace them with Kohler VR's. This is the Kohler part # that I use 41-403-10-S regulator.
Thank you everyone for all your help, the final fix was to replace the regulator, I had one off of a spare engine. I finally get the cut some of my lawn LOL. You guys are a lifesaver.
Old 06-22-2023, 09:50 PM
Going to order one, may need help with the wiring.
41-403-10-S
