Old 05-09-2011, 12:50 PM
shouldwe's Avatar
shouldwe shouldwe is offline
Sounds like you should have spark in no time. That is some nice looking equipment you got their, some rare stuff.
Have you driven a cub lately
Old 05-14-2011, 11:05 AM
manyhobies manyhobies is offline
Thumbs up Nice find!
When I bought my 3 acres the guy had mostly did the "clean sweep". I do wish I could have seen what was here before! I did buy the 1 ton Dodge with plow and got to use it after a timing chain and clutch install. The clutch was the reason why I got it. The first guy that it was sold to, came over and dropped a battery in. It started. Went to put it in gear and the gears only ground! The guy turns of the engine and says: "I don't know how to work on Dodges". Takes his battery and walks.
Keep looking around your place, you might be supprised what you'll find! How much land did you get? I take it you didn't do a presale walk through!Becareful what you throw!
Did I read that you're an engine builder? I take it that small engines are a new hobbie to you. Keep learning!
Oops! Time to get off of the computer and get to work changing the ball joint on the van.
Good luck!
Hello. My user name says it all. I have a lot of hobbies. I have a 1250 Cub that I just got and will be working on it. It runs fairly well. :
Old 05-15-2011, 12:52 PM
HKTackdriver's Avatar
HKTackdriver HKTackdriver is offline
Well, I learned about the joys of carburetor flare up today. Only half of my eyelashes are singed though, so it's not a total loss! Still not running, my plug wire didn't arrive.
Old 07-24-2012, 09:45 AM
Default cub cadet 122
nice 122, i have one also i like the chipper shredder they are rare
Old 07-24-2012, 05:54 PM
David a Calkins David a Calkins is offline
Default clueless please help
the last 122 i found looked like that ,i would start with looking in the fuel tank ,i bet its full of rust ,i would start with a remote fuel tank ,clean out the carb ,check the points ,or replace ,check for a good ground ,replace with new oil ,removespark plug ,,see if it will roll over ,replace plug ,and the starter genertor may need some attention .hope this helps .David
Old 07-25-2012, 06:37 PM
jcsmith jcsmith is offline
Default 122
also check the points pushrod,or better yet replace it. It should pull right out. if not , it's probably boogered up inside. Nice find. Have fun, Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
