#41
You have a safety switch or relay problem. PTO is OK since it will engage when you hold the switch.
#42
Yeah....
Check the Seat Switch, Reverse Switch to make sure the Reverse Relay is being energized.
#43
Thanks Guys !
Turned out to be that one of the leads had come off the side terminal tab on the reverse switch. Appreciate it ! |
#44
I had the same trouble and had to remove three bolts that hold the controls on and pivot them enough to get an offset box wrench on. |
#45
Found a wrench that fit, sort of and got the job done.
