Old 06-27-2012, 02:07 PM
mrcubcadet's Avatar
Originally Posted by Darrell View Post
I seen you where you are going to have your hydro check valves rebuilt , i would strongly suggest getting the automatic valves instead. They are ALOT more convenient , especially once your flapper that holds them down breaks. They may seem pricey , but well worth it.
Go Here .... http://onlycubcadets.com/
The link ain't workin' , go to Technical Library , Tractors , Hydro Check Valves , and there is a supplier.
Sorry for just getting back with you on this...But I have already had my manual valves rebuilt.
Auto ones defiantly are more convenient, but I probably won't be having to push this tractor much, anyway. HOPEFULLY!!
-105___ Tiller
Old 06-27-2012, 02:09 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Looks good Conner!
Old 06-27-2012, 02:16 PM
mrcubcadet's Avatar
Thanks, Adam!
I hope -with all the work being put into it- that it looks nice at the end!
-105___ Tiller
Old 06-27-2012, 04:32 PM
mrcubcadet's Avatar
Took the drive hub off of the input shaft, to have it re-machined..Also zipped off the wheels real quick with the Dewalt impact.
-105___ Tiller
Old 06-27-2012, 10:00 PM
mrcubcadet's Avatar
Finished priming the frame, then power washed the rear end, and started priming it. Will be finishing, and starting sanding tomorrow, and hopefully be ready to shoot the frame and rear end this weekend.
-105___ Tiller
Old 06-27-2012, 10:36 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
when its done you'll be like me and not want to get it dirty. but once you get it back in the dirt you wont care
Doug
Original , 100 , 125 , 582
Old 06-27-2012, 11:33 PM
mrcubcadet's Avatar
I've already done a little thinking on whether I'm going to use it much or not!
At the most, might run a 48" deck. After I paint it, too...That is!
-105___ Tiller
Old 06-28-2012, 11:14 AM
Conner your off to a great start!
Old 06-28-2012, 12:09 PM
Keep the good work up, Conner!
Old 06-28-2012, 02:15 PM
TheSaturnV's Avatar
My tractors get the filthiest by using the mowing decks. Go ahead and put it to work, the dirt washes off!
