Old 10-21-2012, 07:32 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
4speed can't wait to see the NF with the Chevy small block in it.
Im a Pontiac guy , SOoooooooooooo you'd never see me using a sbc for anything other then a boat anchor
I have a 22 hp kohler command in a old lincoln welder/generator that runs on propane
Doug
Original , 100 , 125 , 582
Old 10-21-2012, 09:08 PM
Doug
The only thing GM ever built that was any good was the sbc. Well maybe the new LS engines. The pic is me and a few of my buddies spanking the sporty car kids a few years ago at Watkins Glen. The #60 is me.
Old 10-21-2012, 09:10 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Personally I am a Ford guy, but I know just about everyone will jump down my throat for it.... but I will always be one.
BTW that's awesome that you got to race at Watkins Glen!
- Cory Sanderson
Old 10-22-2012, 08:50 AM
fhadderton's Avatar
fhadderton fhadderton is offline
The only good use I have ever seen for a sbc is an irragation motor. I run 3 sbc and 2 bb. the 350s use oil and dont like to run, the only reason for them is because parts are dirt cheap. Personaly Im also a Ford man, well Ford, International, and Peterbuilt (gotta love a catterpiller engine). BTW good job on the frame, nice fab work! My 149 has twin 14hp briggs (PO). I have been thinking about going with a bigger power plant for it but until I blow this one I probably wont change.
Old 10-22-2012, 01:32 PM
Same here!
Old 10-22-2012, 08:34 PM
Duke
These pics are just for you. I guess I was wrong when I said you guys didn't need to see pics of a steering box but you wanted pics. So here is one of the box for the 71 and one of a box for a JD
Old 10-23-2012, 09:43 AM
Duke
Thanks buddy! What grease did you use?
Old 10-23-2012, 02:16 PM
The same stuff I use on everything I own. Mobil 1 as you can see from the can
Today was a Green tractor day. Had to build a new engine mount for the 317 with the Honda. It had a SEW repower kit in it when I bought it and the engine was mounted 3/4" too far to the right so the drive shaft was hitting every time you hit a bump with it. Also fixed the PO's wiring mess. Some 3/8" steel plate and Mr. Miller took care of the mounts. Tossed the rubber mounts in the trash. Thing runs SWEET!
Only Cub thing I did was to press the new bushing into the 3 pin clutch driver. Hope to get the new clutch tomorrow. One more test fit and then I'll squirt some paint on the old girl and start putting it back together.
Old 10-23-2012, 06:02 PM
The same stuff I use on everything I own. Mobil 1 as you can see from the can :
I thought it was there for size reference.
Old 10-24-2012, 01:13 PM
Good day today, the guy with the brown truck showed up and brought me this!
