Old 09-25-2013, 12:58 PM
Top notch work DWayne
Old 09-25-2013, 01:02 PM
cubs-n-bxrs's Avatar
Nice job Dwayne.
Old 09-26-2013, 05:19 PM
I thought I had my clutch all put together correctly going by pictures of the old one, and then I come to find out thru the parts diagram there is a spacer that fits in front of the release bearing and behind the teaser spring. I ordered the part and got it put on today. I thought I would post a picture of the Clutch spring components and show the order they go. This would have helped me a bunch. Come to find out, that whoever rebuilt the clutch on the 128 in the past did not use that spacer.
Old 09-26-2013, 05:22 PM
Originally Posted by rmunro View Post
That thing didn't look that good 40 years ago when it was new.
very nice.
The upside of pictures, they hide things you see up close with your eyes. But thank you.
You 128 is looking great, DWyane!
I have this place to thank for giving the courage to try something this in depth.
Thanks buddy, but I have seen your work, I have a long way to go to match your quality.
Nice job Dwayne.
Thank you very much, I am enjoying finally seeing the light at the end of the tunnel now.
Old 09-27-2013, 12:00 AM
You are to kind, I do the best that I can do with what I've got.
Old 09-30-2013, 05:19 PM
Another great day to work on the 128 some. I was able to get the clutch installed on the frame and adjusted. I got the PTO rebuilt and installed too. I had forgotten I had a PTO adjustment tool and happen to find it in my tool box. Just ordered the 3 pin drive plate bushing for the clutch shaft and the Clutch safety switch spring. They should arrive in a couple of days. My electric harness should arrive around that time also, so I will be able to get the harness in and then set the motor in once I press in the bushing for the clutch shaft. It's amazing how much dust something can collect even when covered in sheets.
Old 09-30-2013, 06:14 PM
Cool! Thanks for the update Dwayne!
Old 09-30-2013, 08:39 PM
That's good news DWayne, thanks for the update
Old 09-30-2013, 09:55 PM
Thanks for the update on your 128, DWayne!
Old 10-01-2013, 11:10 AM
ajcombs's Avatar
ajcombs ajcombs is offline
Looks great!
