Old 11-13-2013, 12:14 AM
782CC 782CC is offline
I ended up building a ripper to do the patch of yard in the pic. Was just to much to risk breaking a Tiller I like.
Old 11-13-2013, 12:44 AM
The tillers will shake and beat when you try to till sod with them. They aren't really made to break ground. Best thing you can do is either plow first, or just slow way, way down and let it work. The tine speed really isn't where it needs to be for ground breaking. But, I don't think speeding it up is a good idea for the style of gearbox it has. I have considered it, but I just went and bought a plow. Problem solved.
P.S. they don't like roots and bricks much either, LOL!
Old 11-13-2013, 12:45 AM
Yeah, there ya go! Good call!
Old 11-13-2013, 10:08 AM
MinnesotaCadet's Avatar
I still have yet to get a moldboard plough. That would help a lot.
Connor
Old 11-13-2013, 10:12 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
The plow and ripper idea sounds awesome! Do you have pix of your ripper? I am tempted
1- 1200 in pieces
1- 1864 in pieces
Old 11-13-2013, 10:21 AM
OldAndInTheWay's Avatar
I guess I have the ripper, box drag, blade and dirt scooper all tied into one with my Earthcavater.. I have never seen one in action. Don't think many people around here ever heard of one. I will have to play with it someday to learn how to use it.
Plow first is the only way to really make it easy on you and your machine.
Old 11-13-2013, 10:44 AM
I posted a pic of the ripper in my album. Was rushing and did not build it very well honestly. Not enough range or adjustment. Plus bought the shank at tsc. Another on here bought 4 online for what I paid for one shank. Forgot to mention. I had to hang several rear weights on it to get it to sink. 682 has no weights to needed it for traction anyway. but important note I think.
Old 11-13-2013, 10:46 AM
When I acquired my dad's tiller this spring just about every nut/bolt was loose on it. The land he used it on is full of field stones and they made it bounce like crazy. One learned to shut off the tiller quickly when a rock became lodged, which happened often. Stuff grew good, but boy did it bounce. On my property, the soil is blackish clay stuff, and I didn't have to worry about it jumping as much. I tightened it up before I used it and had no issues breaking through the sod layer. No pre plowing/ripping here.
Old 11-13-2013, 10:58 AM
I tightened mine as well as I tested out the (new to me tiller). Sharpened tines etc... Still very hard on it catching roots. Ripping I found a very large rock 100lb... That the tiller had bounced off of. Would have broken the tiller trying to bust that up. All this in my suburban yard btw. Personal preference but I will always try to break up the ground before I till. (unless I have already run a tiller across it)
