Old 12-13-2013, 10:57 AM
Sam Mac Sam Mac is online now
Originally Posted by KayakDon View Post
So, from what I've read here and looking at the parts list, it looks pretty easy to install the valve. The hard part for me will be the pipe/hoses. The closest to doing hydraulic lines were just simply replacing a leaking part with a new one.
From what I can figure is I will need the original pipes off of a valve and partway down add longer hose to the front, then the quick connectors. Does that sound like the best plan? Should I be looking on ebay for some used pipes, or buy some new ones at $65.00 apiece? Am I be better off bending new pipe all of the way to the front? I wish I could find the premade parts so I could just do a bolt in,(I love pre bent pipe) but I don't think that will happen. Just some random thought while I wait for parts! Don
http://www.ebay.com/itm/New-Cub-Cade...item43c2f61252
Look at this stuff! Could I make some of this stuff work? Or not!
http://www.ebay.com/itm/Cub-Cadet-18...item232ce161dd
This looks like the right pipe to valve body I need
These should work but you will probably need to extend them to reach the front.
Old 12-13-2013, 02:55 PM
Captain B Captain B is offline
Guys
I don't understand why most of you are asking for more that 1 of these things? As far as I know you only need 1 to go between the 2 valves. Like I said before I am not doing this conversion myself nor have I ever seen one in person. I have no need for front hydraulics on my Cubs. Reading the manual for the Cyclops front hydraulic kit it only shows 1 of these adapters needed. The adapter goes between your existing valve and the valve being added allowing the fluid to flow from the existing valve into the new valve. I think the bigger issue for those of you will be the hoses. That said this is the list of members that have expressed interest in the adapters and the quantity they have told me they want. Let me know if you wish to change the amount.
Rescue11 3
Oak 1 NC because he is supplying the OEM part to copy.
V30crewcab 2
Jubilee 2
Cubyfan 2
Captain B 2
LiamD 1
Yep, I am still in for 2. Yes, I only need one for the current project but at the price we are talking, I figure it's worth having a second one. You never know when another project will come up. There are also 2 other cyclops in the extended family and they may need one in the future. Thanks Sam.
Old 12-13-2013, 02:59 PM
TIMCRUTCHER TIMCRUTCHER is offline
I bought used hoses from one of the site sponsors. Used the metal flare portion and had new hoses of correct length attached.
Old 12-13-2013, 05:15 PM
I'd like to see some pics of the hoses when you get a second.
Thanks
Old 12-13-2013, 06:27 PM
KayakDon's Avatar
KayakDon KayakDon is offline
Default valve
I got my valve from Sam today
Bought the used hydro lines on ebay today.http://www.ebay.com/itm/Cub-Cadet-18...item232ce161dd
Looking forward to finding the time and the quick connectors to finish this project. Hydraulic hose shop for the rest? Pictures will follow. Thanks to all for your input. Don
Old 12-13-2013, 07:59 PM
Don
Good to hear that the Pony Express got it done.
I got the adapter from Oak today so Monday AM I will be off to the machine shop with it. I'll keep you guys posted on the progress.
Old 12-13-2013, 10:19 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Thanks Sam-man
1- 1200 in pieces
1- 1864 in pieces
Old 12-14-2013, 12:42 AM
CTRUEX CTRUEX is offline
I now know why these valves are going so quick on eBay!!! You need to use the O-rings and the backer rings. The backers will keep the O-rings from blowing by and leaking everywhere. For us non-Cyclops fellows, and Cyclops owners alike, these valves are machineable. Make sure to fully disassemble the valve before drilling and tapping, and make sure it is clean and free of burrs before reassembling the valve. From the looks of it, at least on the 2082's dash and tower that I have, three valves can be added to the Cyclops, and more on a custom build. The only problem is once you start paying $50+ a valve, the Greene H3 valves start looking like a better solution, at least for custom applications.
Old 12-17-2013, 12:49 PM
Got my valve from one of the sponsors. Now I am looking at having a local shop make some custom hydraulic hoses up. Does anyone know what the name of connection into these valves is called?
Thanks!
Old 12-17-2013, 06:18 PM
Thanks!
Pretty sure they are called "Cub has you by the you know what's fittings". I looked through my Aeroquip and Parker catalogs and can't find anything like what Cub used.
Just an update the machine shop is making those adapters for you guys, I'll keep you posted.
