#41
Finally was able to remove the seized manual lift handle. Broke one of my 1/4 inch solid carbide drill bits in the process, but not before most of the roll pin was gone. Finished up with a regular/nitride bit, and, with judicious application of heat from a mapp gas torch, was able to knock the handle off. Frame is in the truck with the dash tower, and a few other odd bits--QA handle, brake caliper supports, lift index. Next stop, sandblast shop.
Nice job with the tear down, those rusted and frozen shafts and stuff can be trying but you got it. I too am getting most things blasted these days. I will say that you should take up your blaster on his offer if he is a good painter, not sure about the sherwin williams paint, What type of paint is it?I'm trying to get away from rattle cans even though they are super convenient, I'm just so tired of the TSC majic paint and how it wrinkles and runs and never dries, ugh. What cans are you using dad? Sorry if you've stated this before. I'm really leaning towards buying the good stuff and have our painter at work do it. So much prep and money to get stuff blasted you might as well do it that way, I'm going to as well.
#43
On my previous tractors (8 of them) I've been using the Case/IH rattle cans, purchased either mail order or from the local dealer--at $10 to $15/per can. A tractor typically needs 4 or 5 yellow and 3 or 4 white, so I'm in over $100 for the rattle cans per tractor. The Sherwin Williams shop recommended an industrial fast dry enamel, at $46 per gallon. Ordered one gallon of each this morning, will pick it up tomorrow and take it to the sandblaster. I forget the name of the paint he suggested. He used paint from my rattle cans to match the colors. I'll report back on how it works, and, perhaps the color codes in case anyone else wants to take this approach. I might pick up an HVLP painter to try for some small parts.
Picked up the paint and took it over to the painter. Here's what I got. They mixed the yellow by tinting the safety yellow they already had.
Edited A week later: These colors are not an exact match to the IH colors--the yellow is darker and the white is not right either. Side by side with IH Rattle Can colors, the difference is quite noticeable. If you use these colors, you'll need to complete the entire project with them. Rattle can touch ups will not match. Managed to clean up the rear end, so it's drying now, and next step is to prime and paint it. Started working on the clutch assembly. Faced the clutch pressure plates on the lathe. Both springs are broken (compression spring and teaser spring). All the roll pins came out without any problems. I have a teaser spring, need to order the larger spring. Once I clean these parts up, and get them primed and painted, I'll set them aside until it's time to install them.
Update--ordered more parts, plus all four tires and new front wheels because the ones on the tractor have loose bearings. Started looking at the total list of parts.
![]() ![]() ![]() Thought I'd provide an inventory of parts purchased for this build. There may be a few extra parts (I'll sometimes order a couple if I want to have an extra on hand or for another project). But most of this stuff is for the 1000. Plus, I’m pulling tune up parts, front axle pin and a few other parts from my current hoard, so they are not listed here. So I’d say this is a reasonable approximation of the cost for the overhaul. It's a little daunting when you see it all in one place. Part ID Description Quantity Unit Price Subtotal CUB 924-3000 Pad, Pedal 1 11.20 11.20 CUB 932-3005 Spring, Clutch Release Rod 1 6.16 6.16 CUB 932-3015 Spring, Pedal Return 1 7.38 7.38 CUB 932-3000 Spring, Safety Switch 1 14.08 14.08 CUB 941-3056 Bearing, Throwout Ball 1 56.78 56.78 CUB 00012118 Knob, Creeper Shift Lever 1 9.49 9.49 CUB IH-548122-R2 Stator 4 38.85 155.40 CUB IH-401466-R1 Knob w/Product Graphic, Shift Handle 1 16.28 16.28 CUB 925-3060 Switch, Neutral Start 1 20.11 20.11 CUB KH-47-883-01-S1 Element, Air Cleaner 1 13.06 13.06 CUB KH-25-757-02 Kit, Carburetor Repair 2 14.90 29.80 Taxes: $0 Standard Service Shipping: $7.95 Grand Total: $347.69 16x6.50-8 Deestone Tractor Lug 4 ply 550074 2 $35.00 USD $70.00 USD 23x10.50-12 Carlisle Tru Power 4 ply 523367 2 $100.00 USD $200.00 USD 8x5-3/8 Steel Wheel, 3" hub, 3/4" Bearing WDC83XPF34 2 $42.00 USD $84.00 USD Subtotal: $354.00 USD Shipping: $112.00 USD Grand Total: $466.00 USD HD) Clutch Springs $31.30 X 1 = $31.30 (R) (Spring: Red - 800 lbs. ) (T-Cup) Teaser Spring Cup $14.00 X 1 = $14.00 (Teaser) Teaser Spring for Cub Cadet $5.18 X 1 = $5.18 (TO1) Throw Out Bearing for Cub Cadet $55.00 X 1 = $55.00 ---------------------------------------------------------------------- Product Total $105.48 Shipping (2) $17.75 ---------------------------------------------------------------------- Grand Total $123.23 NEW OEM PTO CLUTCH BEARING IH 60071 C92 IH 473470 R91 IH 60069 C92473478R2 : 1 : 32.00 FRONT PTO WEAR BUTTON 473477R2 : 2 : 7.50 NEW OEM FRONT AXLE COILED PIN IH 591184 R1 : 4 : 2.00 NEW TIE ROD END 723-3018 723-0156 923-3018 923-0156 IH 392594 R1 923-3000 723-3000 IH 406304 R1 : 4 : 10.00 STEERING COLUMN UPPER BEARING (BUSHING) 400501R1 741-3023 : 1 : 4.00 NEW STEERING GEAR SEAL 723-3040 405304R1 : 1 : 3.00 NEW OEM SEAL and SEAL RETAINER PACKAGE IH 394936 R91 : 1 : 11.00 NOS DASH TIN QUIET LINE GEAR : 1 : 130.00 NEW OEM CLUTCH SPRING SPACER IH 60524 C1 911-3040 711-3040 : 1 : 12.00 CLUTCH TEASER SPRING IH 376260R2 932-3017 : 1 : 4.00 NEW OEM CLUTCH RELEASE PIN 711-3044 IH Q 589 : 1 : 5.00 AIR FILTER 759-3547 KH-47-883-01-S IH 117210 C1 100107 : 1 : 11.00 NEW OEM IGNITION SWITCH IH 61524 C2 : 1 : 19.00 PTO SWITCH 725-3022 925-3022 : 1 : 27.50 NEW OEM NEUTRAL START SWITCH SPRING IH 544128 R3 732-3000 932-3000 : 1 : 12.00 NEW OEM SAFETY STARTING SWITCH ASSEMBLY 725-3038 925-3038 IH 382728 R91: 1 : 38.50 NEW OEM HEADLAMP MOUNT RING IH 107277 C1 IH 107333 C2 : 2 : 24.50 Subtotal : 421.00 Shipping : 10.00 TOTAL : 431.00 8.5 inch wide Rear wheels--$75 (ebay) QL Headlight assy=--$51 (ebay) creeper gear--$250 (ebay) Paint $96 (2 gal Air-O-Jet) Paint $10 (rattle can Primers) Paint $30 (IH rattle cans) Wheel weights-$125 (local purchase) Seat Northern Tool, $99 + shipping = $113 washer fluid for tires, two cases, $28 (Advance Auto) That totals to about $2000 not counting the duplicate items or items ordered for another project. Also does not include the $300 for the tractor itself. I still need to add the sandblasting, priming and painting fees. Once I get the total for that work, I'll add it. I expect that to be close to $1000. I have not done anything with the engine yet. Some progress on the rear end. Pulled the axles, replaced seals, drained what looks like gear oil from the rear end, cleaned everything up and painted. Obligatory pics.
Doesn't take long to add up quick! Will be nice when you are done though!
#48
Amazing how fast it adds up. When its all done it's easy to put $3000.00 into one of these restore jobs. Only problem is that you'll get your $$$ if you try to sell it. Ask me how I know. BTDT. Anyway awesome job as always. POTW when your done.
#49
Where did you order the parts from? What about the tires?
I am working on a 1450 basket case and thought I had a boat load of parts coming. Wow! I got many used parts from guys on this and other forums. Where did you get the tires? My tractor needs them badly. I want to put tri-ribs up front and ag tires in the rear. |
#50
Parts from CC specialties, IHCCwarehouse, partstree.com, and miller tire for the tires.
I used to buy a lot of stuff from Charlie at CCspecialties, but he's still trying to get stuff back in stock, so I've been going where I need to. edit: forgot--I bought decals from maple hunter a month ago.
