Old 01-16-2014, 12:25 PM
1811woody's Avatar
If I could only get the little woman to park her car outside I'm sure she'll go for that this would be me If I even suggested it
You know these very well can I change the ignition module without pulling the motor?
Old 01-16-2014, 01:21 PM
You know these very well can I change the coil without pulling the motor?
1872 should have a Mag 18 in it. The Mag18 has an ignition module not a coil. It's mounted to the back of the engine under the blower housing. You get to pull the engine if it is in fact bad.
Old 01-16-2014, 01:55 PM
The engine will have to come out to change it.
Old 01-16-2014, 03:20 PM
I have a 782 with a M-18 in it.
I changed the coil/Ign module last summer and I didn't pull the engine.
IIRR, I removed the gas tank, firewall, rear fan shrouding bolts and kind of pushed it back and other things that were in the way to get to the coil on the head.
I put a .010 piece of metal over the magnets on the flywheel to properly space the coil assy away from flywheel.
and tightened things back up, it was not that bad of a job really.
I'm thinking the 1811 is similar?
Old 01-16-2014, 04:29 PM
Tom Scott Tom Scott is offline
You have not conclusively proven that the ignition module is bad. That is a lot of work to replace a part that may not be bad.
It may be as simple as low cranking speed. The small batteries used in these come in a variety of flavors from crap to pretty stout. I just replaced the battery in my 1872 due to cranking too slow to fire in the cold.
If you need a battery, the only number to look at is CCA (Cold Cranking Amps, measured at 0*F). The other number is just CA (Cranking Amps, measured at 32*F); no need to pay attention to both numbers.
Only look at the CCA number. There is no way to make that number high without making a better battery. Some crap batteries will not list the CCA; if they won't show it, you can bet it is low.
The best I found was at Advance Auto Parts, 340 CCA ("Lawn & Garden Pro"). The worst I found was also at Advance, 160 CCA. The price difference was substantial for a reason, it costs more to make a better battery.
With the 340 CCA battery, the cranking speed is substantially better. Also make sure your cables are in good shape and use dielectric grease on all connections to keep the corrosion away.
You can't troubleshoot it until it doesn't work again. The next time it won't fire, try some starting fluid. Often they are cranking too slow to fire on gasoline but will fire on ether. If it fires on ether but won't stay running on gas, you have a fuel delivery problem. If it fires on ether, stays running on gas, and never has a problem at any other time, it is probably just cranking too slow.
If it won't fire on ether and the cranking speed is reasonable, then it may be the ignition module. Check for spark immediately during this troubleshooting session before something changes, not the next day when conditions are different.
Get two spare plugs for checking for spark. The Kohler manual recommends using one of these two plugs gapped at 0.130" when you are checking for spark external to the engine to simulate combustion chamber conditions (compression). This is generally done by just removing a portion of the ground electrode of the test plug to create the large gap. (Measure to be sure of the gap.) Connect both test plugs to the plug wires (one with normal gap and one with the large gap) and ground the plug threads using large electric test clips wired to the engine ground. (Don't remove a plug from the engine or you will increase the cranking speed due to the lowered compression resistance, and you will be changing the conditions the engine is experiencing.) The Kohler manual does a good job of explaining this and has a diagram. The Kohler service manual is available here: http://www.kohlerengines.com/onlinec.../tp_2204_b.pdf
The Kohler manual has a second test using an ohmmeter that can give assurance of a module problem. If you are not getting spark, make sure you don't have the kill wire grounding accidentally. Unhooking it at the engine for the test is one way to troubleshoot this.
Ignition modules (magnetos) can be intermittent, but it won't stay that predictable. If it is really a problem, it will become more and more apparent.
Good troubleshooting is proving something is good or bad before you move on. Guessing and just replacing parts will make you crazy and poor! Good luck!
2135, mowing duty at parent's
1872, 46", 50C decks, Haban dozer blade, 450 snow blower
2182-1, Kwik-Way Loader, 3-pt & rear pto, 442 tiller
2182-2, 54" deck, 451 snow blower
Old 01-16-2014, 05:16 PM
Good stuff Tom
Only thing I don't like is using starting fluid. I've seen too many bad results from it the hands of people that use too much. The fact that he got it started once it was warmed up a bit leads me to believe the battery may not have enough oomph or the connections are poor. I'd also add that the battery cables on most Cubs are too small to carry enough current in cold conditions. Had a 1210 that would not spin fast enough to get going on cold days. Replaced the cables with welder cable and a ground straight to the engine block, problem solved.
Old 01-16-2014, 05:58 PM
I agree that ether should be used in small doses, for troubleshooting or emergency use only. It takes very little to make an engine fire, just a half second squirt.
Based on everything I have seen in his history with this problem, my bet is also on the too slow of cranking speed. I outlined the spark check just to be sure if needed.
I also agree on the battery cables, Cub skimped here and larger is better. Dielectric grease on every electrical connection will keep them good. I put it on every wire before a crimp and in every terminal before connecting, including battery terminals.
The battery quality is a real issue too. Unless someone has read up on it they may not realize that the same physical size battery can vary so much in power.
Old 01-16-2014, 06:25 PM
Maybe pull the battery out, put it in a warm location on a charger all night and try it in the morning and see if it starts. It sounds to me like your battery is getting weak. I have a good ignition module I will ohm out for you to test yours and they also explain that in the manual.
Hey, if these things ran when we needed them they wouldn't be any fun. Don't give up, we are here to help.
Old 01-17-2014, 01:24 AM
1811woody's Avatar
I kinda thought so thanks for the info Allen.
Great info guys! Thank you Tom for taking the time to type up that extensive explanation. At this point I'm going to take one thing at a time starting with the most logical step first based on what I'm seeing and reading and my past experiences. I had mentioned somewhere in the beginning that I felt the battery was doing a good job of turning the motor over plus it seams to have a pretty good reserve. When it does finally drag down because of a no start I put my booster on it and crank some more with out success so I believe I can probably rule out the battery or at least put it towards the bottom of the list of suspects. Sam The cables at this point because the battery seems to crank the motor over pretty good I will upgrade in the future but at this point because it does crank pretty good I'm going to put that towards the bottom of the list of suspects. I do like the idea of a better ground going right to the engine and may do that regardless.(I'm keeping in mind I may have to eat crow later on but I have to start somewhere). At the top of my list is to check the ignition module I have borrowed a spark tester from a fellow worker from the shop that will give me a accurate answer to whether or not the ing module is putting out enough spark (15000, I believe is what he said) so I'll see what happens tomorrow morning and then go from there. Oh and Oak I cant give up I've got to much wrapped up into here to stop now. It would also be nice to know what your ignition module ohms out to so I can bench test the one I have sitting here Thanks! George I'm going to look real hard at changing without pulling the motor in case I have to this is on a 1872 if you were able to do it on a 782 I surly should be able to do it on this one. I'll know if I need to change it tomorrow. Thanks for the info
Old 01-17-2014, 01:27 PM
1811woody's Avatar
I got out this morning to check spark with the spark tester and it looks really good so that says the ignition module is good I will read in the service manual to do further test but this tester is supposed to be cut and dry. While I was out I checked the cca of the battery its rated at 340 and as I mentioned has plenty of power to crank it over even when freezing . I'll keep looking I havnt given up yet. I'm wondering if I'm just plain flooding the thing? Although I'm not smelling gas, if I am its flooding way to easily next time it doesn't start I'm going to pull the plugs and check to see if their flooded.
I'm new to adding vidoes to youtube but if I did it right it you should be able to see the test under 1872 spark if you want to see how much spark I'm getting The spark test was done with it sitting in the garage over nighta at about 45 deg I drove it outside and after it sits overnight I will check again in the morning.
