#41
I came home from work last night and spent a couple hours and got the bucket all mounted up everything went together easily its well designed and the directions are pretty good. I left the electrical for this morning running the wires was not an issue but figuring where to put the switches is still in the works I hate cutting holes in the dash not only that but it wouldn't be a real ideal location reaching around the steering wheel. I got to play in the dirt a little bit. The faster tilt actuator for 50.00 extra is really a plus it could use a faster lift actuator also it sure is slow. I had a full bucket of sand loaded in it and didn't need any ballast the 1872 seemed to handle it without a problem but just in case ill go ahead and load the tires. Heres a couple of pictures of it . Ill add a few more later
2014-04-12 00.29.06.jpg 2014-04-12 00.29.29.jpg |
#42
Looks great! Can't wait to see some action shots!
#43
Looks good mounted up! Congrats!
#44
Where is the dump actuator?
1811 Hydro "Failing to prepare is preparing to fail".
#45
Heres a couple of more shots, this is wet sand/dirt pretty heavy stuff no problems handling this. I bounced on the front end to see what kind of load the 1872 would take so with a added 250 lbs to the bucket load and 250 lbs less on the seat it didn't come off the ground nor feel spongy at this point I think I can hold off on any ballast. I did order a pair of 2 link tire chains to give me some more traction
#46
Great shots on the 1872 and JBJR!
#47
#48
Here is mine fully dressed and ready to take on the pile. I have found that the extra weight of the box scraper is unnecessary. Filling the tires and adding the wheel weights is though. Once the tires dig in, the box blade hits the ground and really gets you stuck.
#49
#50
