Old 10-23-2014, 06:12 PM
Good progress sam.
Old 10-23-2014, 07:07 PM
what he said,
I guess yours,with those leaking valves,it becomes a dirt collector.
Up to 534 and counting...
Old 10-23-2014, 07:38 PM
what he said,
Yep, nothing like a little oil being blown around by the fan and some dirt. BTDT. I've seen worse. I'll pull the valves and send them to Machtech to be rebuilt. Still going to pull the rear and do the axle seals, drill the return holes and replace the cork gasket. Trunion also needs some TLC. Not sure if I'll open the pump and do all the pump seals have to inspect that a little closer. This is all part of the deal on a 1000 +- hour 20 year old machine. It will still be less $$$ than a new throw away Big Box store turd, and it will out last one.
Old 10-23-2014, 10:01 PM
rwairforce rwairforce is offline
ill drink to that.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 10-25-2014, 06:41 AM
reidcc's Avatar
reidcc reidcc is offline
Nice work and nice find Sam-
Amazing to see stuff like this. Wish I had the time, knowledge, and SPACE to cover things like this.
Love your jack platform too!!!
Enjoy-
Chris
Old 10-25-2014, 05:51 PM
Enjoy-
Chris
Chris
I have to thank Cub Crazy for turning me on to the guy that had the lift tables for sale. Best tool I ever bought, without it I wouldn't even consider doing to stuff I do on these Cubs. The knowledge has come from doing and reading the service manuals. Sort of like going to school.
Old 10-28-2014, 12:44 PM
jimbob200521's Avatar
How's the 2284 coming along, Sam?
-Ryan
Old 10-28-2014, 03:45 PM
It's a 2182. Haven't done much the last couple days, closed the pool and today the weather is awesome so I took the Harley Night Rod out for some seat time. I did get some rear end cover plates made up out of 1/4" steel plate.
Old 10-28-2014, 04:27 PM
Doh! That's what I meant Good to hear the project progresses
-Ryan
Old 10-31-2014, 04:04 PM
Got a few things done today. I eliminated the fuel shut down solenoid by drilling the bolt that holds the float bowl to accept a 3/8" freeze plug. Got the plugs from NAPA part # SEP 381-2185, cost a whole 69 cents each. Reason I did this is that when I wire it I won't need to deal with the diode and wiring for it, plus it makes it a lot easier to get to the distributor. First 3 pics show what I did. Then I pulled the rear out. Every seal on it leaks, like that's a surprise. Next 4 pics. Then I pulled the bearings out of the PTO, I wonder why it was making screeching sounds? Also looks like the PO never used a grease gun on the drive shaft.
