Old 11-17-2014, 01:16 PM
I believe if that engine revved to 7000rpm you would have a pile of scrap iron or a boat anchor whatever way you want to look at it.
I agree Kelly.
I'm gonna say the meter isn't correct.
Old 11-17-2014, 01:52 PM
jimbob200521's Avatar
I agree Kelly.
Probably set wrong; I had one that would read about 7000rpm until I changed to the wasted spark setting. 7000/2=3500 so I'd guess he isn't that far off. If anything, he'd want 7200rpm.
-Ryan
Old 11-17-2014, 01:56 PM
Guys, if the meter is set wrong, it would read lower. I.E. if it was set to wasted spark, it would read really low. If it was set to 2 cyl it would read low, and so on. On a single cylinder engine with no wasted spark, there isn't a setting that would make it read faster. So..... that just leaves the meter didn't work, or wasn't reading correctly.
Old 11-28-2014, 04:31 PM
Rob C's Avatar
Rob C Rob C is offline
Sorry took so long guys. Work kickin my butt. The guage I have is nothing special. A piece of tape i placed around flywheel and RpMs are measured. I since borrowed a buddy guage and mine was way out compared to his. I've got it set now at 3600 wot.
I'm in the process of changing hydro fluid. Before I go ahead with that I have a concern.
While at a stand still the engine holds RPMs fine. As soon as I move the speed control lever to go The engine loses RPMs drastically. Could this be a fluid/filter issue? My concern is, if I change the fluid (expensive for hytran), Am I possibly wasting it due to me possibly having to fix hydro issues.
This tractor has been sitting a bit and I have no idea how long or old fluid/filter are/is.
I'm gonna gap new points to eliminate that and hopefully get timing down right. It's not sputtering at all so It's gotta be close.
Old 11-28-2014, 04:49 PM
cubs-n-bxrs's Avatar
Sounds like you need to reset the governor. I doubt the hydro fluid or filter has anything to do with the RPM's dropping off like that.
Old 11-28-2014, 05:01 PM
Kelly is right. But, there is RPM drop to any engine once a load is put on it. Even with everything set right, it will still drop to a certain extent. If you don't know how to reset the governor, consult the "K" series service manual.
Manual:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
You DO NOT gap points to set them. You set the timing. If you don't know how, here's a How-To:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Old 11-28-2014, 05:15 PM
Rob C's Avatar
Manual:
With ya... been starring at the post for a bit now..lol. Thx for the help guys. I'll be messing with the governor tonight
Old 11-29-2014, 10:29 AM
snoel's Avatar
snoel snoel is offline
I had the same drop-off, of RPM under load (light). The various holes for springs , can be changed, to increase sensitivity of the governor response. It can dramatically help or hurt the "drive-ability". The manual describes the how to. But you have to read it carefully. My 149, now is very responsive to changing load conditions. It became a much more docile, but ready to perform tractor. And that makes it fun!
Steve
