#41
The clutch release lever looks good at the spot where it contacts the throwout bearing.
#42
And the three pin driver looks good from all angles, although I will be replacing the three drive pins.
#43
So here we go, my parts list;
From; http://midwestsupercub.net/MWSC2015.pdf pg. 10, item # KD, 1 Clutch friction disc, Kevlar/fiberglass. And from; http://www.cubclassics.com/pulling.html 1 blue spring, under pulling parts 1 flex coupling disc, under Cub Cadet Parts, page 1, part # 722-3000 1 teaser spring on Cub Cadet Parts, page 2, part #932 3017 1 ball bushing on Cub Cadet Parts, page 2, part #941-3004 Coiled spring pins from; http://www.mcmaster.com/#steel-coile...g-pins/=vyce3a 07-05-2015, 07:23 PM, Update. For additional clutch build/parts stuff go to; http://www.onlycubcadets.net/forum/s...101#post336101 |
#44
Sound good?
#45
As a side note to anyone in the Connecticut/ Rhode Island area, this guy seems to be trying to move a few tractors, and one is red...
http://newlondon.craigslist.org/grd/4876243827.html |
#46
I would weld in the wallowed gaps and then clean out the grove before re-installing.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#47
I'm curious as to why you went with 2? Did you cut your driveshaft too short for the creeper?
I lost track of what I own a long time ago! |
#48
No, driveshaft actually goes through both flex disks. Two for redundancy, that's the only reason.
Oh, I see.
| Tags |
| clutch, cub cadet 1200 quietline, rag joint |
