Old 04-29-2015, 06:00 AM
Guys:
IF.....you want to mount these in the existing dash mounting hole, it has to be a Tach that is 2" in diameter. The last 3 mentioned, were 3-3/8".
Interesting...The Durite 0-525-10 Tach would be a perfect match... IF it were available here in the USA.
Old 04-29-2015, 10:11 AM
Nitro's Avatar
Nitro Nitro is offline
http://www.ebay.com/itm/FARIA-EURO-B...f6053e&vxp=mtr
I get these will work for the stator charges QL and up, but will they work on the S/G machines? I read one guy took the signal wire and wrapped it around the plug wire to make an inductive pickup, and it worked.
Philip
1450, 1015, and a pile of parts.
Old 04-29-2015, 10:20 AM
That is 4" in diameter.
Old 04-29-2015, 01:15 PM
OldCubby OldCubby is offline
This is the one I am looking at....it states for 4,5,6, and 8, I beleive. But it can be programmed with dipswitches to work with the correct Hertz and has a poteniometer to adjust alittle closer. It recieves signal via W connection on Alternator, in our case, the stator.
http://www.vdo-instruments.com/instr...meter-12v.html
http://www.vdo-instruments.com/media...0Diameter).pdf
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 04-29-2015, 01:22 PM
Guys:
What makes this a perfect match?
Old 04-29-2015, 01:24 PM
It has ALL the correct specifications...
Old 04-29-2015, 01:48 PM
Check out the links I posted, tell me what you think.
Old 04-29-2015, 01:52 PM
Here ya go sir
http://www.ebay.com/itm/DURITE-0-525...-/120748606091
Old 04-29-2015, 02:01 PM
YUP....that is the one I was referencing. Too bad it is in the UK.
Old 04-29-2015, 02:04 PM
They'll ship it to your doorstep as if it was sold here.
