Old 05-11-2015, 01:06 PM
gdheck's Avatar
gdheck gdheck is offline
I'm with Jonathan on the compression fitting. I usually only use them with a soft tubing like copper and with a lower pressure, like fuel line on an old tractor. The brass sleeve and copper tubing combo have never leaked for me, but when you use harder materials it can become a problem. The flared fittings are just fine.
Also, remember that Cub Cadet used a 37° JIC fitting instead of 45°. Your local auto parts store will probably not have the 37° on hand unless they're a darn good store. I know that 45° can be tightened down enough that it will seal, but please get the right fitting. I know Baum Hydraulics in Lincoln, NE has a good selection of them for a very reasonable price and you'll get them fast.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Gdheck,
You are misunderstanding just like I did. Not pipe thread, o-ring seal. It's standard thread.
Old 05-11-2015, 01:18 PM
gdheck's Avatar
Yes, my mistake. Still the next size bigger is going to be 1/2" and I don't know right off how thick the body is. If I have a chance, I will take one apart this week and have a look.
Old 05-12-2015, 11:01 AM
Group_44's Avatar
Group_44 Group_44 is offline
Well, until I get the details worked out to connect the valve so it looks "like it came from the factory" I sacrificed some used lift lines. I cut and flared the ends (jic 37 deg) and will run hoses I had made up to the front outlets. The jic to npt adapters pictured will be replaced with jic to jic fittings to attach to the hoses. I like the idea of reaming the valve outlets to fit the 3/8"push connector but the o-ring seat would have to be also enlarged since it is set up for the 5/16" o-ring on the original fitting. I appreciate all the great ideas being suggested here, my goal is to have a trouble free system I would be proud say I did and doesn't look like it was cobbled together just to get by.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 05-12-2015, 12:30 PM
Nothing wrong with the way you did it.
Old 05-12-2015, 03:33 PM
Group_44's Avatar
I just don't like having to sacrifice the original hoses to do it, they are getting hard to find at a reasonable price anymore.
1641 w/48" Deck
Old 05-12-2015, 03:55 PM
gdheck's Avatar
Guys,
Don't cut up any more hoses. I'll post more in the morning when I get home from work.
Old 05-12-2015, 11:50 PM
Group_44's Avatar
Originally Posted by gdheck View Post
Guys,
The suspense is killing me!
1641 w/48" Deck
Old 05-13-2015, 03:25 PM
gdheck's Avatar
Well, I didn't find what I thought. The counterbore for the o-ring is actually tapered and there won't be much of it left after making the hole 3/8". Sorry for the suspense and then nothing. I Thought I would have one modified by today.
Old 05-22-2015, 01:18 PM
gt383mag's Avatar
gt383mag gt383mag is offline
heres how we did it used old set of lines and some fittings and hoses and she looks like its posta be there think it cost round a hundred bucks and he allready had the parts tractor
