Closed Thread
Old 06-03-2015, 10:30 PM
BassBlaster BassBlaster is offline
No, I havnt done anything to the governor and I don't know a thing about adjusting one. Ill have to read that section of the manual before I mess with it.
I didn't get around to changing the line tonight because I ordered a new wood lathe awhile back and it came today. Spent all evening getting it into my woodshop and put together. After tomorrow, I don't work the next 10 days so Ill have plenty of time to get this tractor sorted out, possibly get the 2165 put back together and spend some time makin' shavin's with my new lathe!
May have to hire someone to bushhog my lawn soon!!!
1994 Cub Cadet 1864
1997 Cub Cadet 2165
  #42
Old 06-08-2015, 01:40 PM
Changing the kinked fuel line did nothing. I still havnt messed with the governor because the manual has a warning that it shouldn't be messed with and Im a little nervous to mess with it. Beyond that, Im at a loss as to wear to go next.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
  #43
Old 06-08-2015, 02:15 PM
Pretty sure the Kohler service manual has a trouble shooting section.
Old 06-08-2015, 05:06 PM
Yep and I had checked everything it said to check except the governor setting so I went ahead and adjusted it. No change. So I played with the sensitivity adjustments and it seems to run the same no matter where I move the spring to. Im at a loss. Ive currently given up on it and Im working on my 2165. I have to get something going so I can mow. Once its running, Ill get back to the 1864. Im not spending much time on it though. Ill go back through the fuel system again which is silly because its all new and if that don't fix it, someone on CL will get a deal on a nice mower because Im done with it.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
  #45
Old 06-08-2015, 06:02 PM
I may not be far away. Keep me posted.
  #46
Old 06-08-2015, 06:25 PM
I may not be far away. Keep me posted. I could trade you a Cub that is running and no apparent current problems.
  #47
Old 06-08-2015, 07:13 PM
CubDieselFan's Avatar
We have all been where you are, so do not get discouraged. Maybe there is a local small engine mechanic that could give you a hand.
  #48
Old 06-08-2015, 08:19 PM
Just a thought.
http://www.onlycubcadets.net/forum/s...411#post332411
Old 06-08-2015, 08:54 PM
Thanks but Im already into this tractor for about 2 grand.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
  #50
Old 06-08-2015, 10:01 PM
j4c11's Avatar
j4c11 j4c11 is offline
Does engaging the choke slightly make the symptoms better,worse or no impact?
Closed Thread
